Question about Dell Inspiron 6000 Notebook
Inspiron 6000 just died
My dell inspiron 6000 just shown a screen flicker in red and everything vanished, i immediatly switched off and kept it off over night, next day it started up and did the same after 3 hours, i had to keep it off again for a day coz it wont boot up, this happened twice, and now the damn thing is dead, after pressing the power switch, 'A' starts to flash and every thing winds down, i checked fan and stuff, everything seems to be wroking fine, there is no power issue, batt is good, no idea of what has happened?
  • Miragedelta Mar 12, 2008
    I suffered the same problem, in fact there is nothing wrong with the lap top, u r having a "dry joint" problem for that u have to open the laptop, ( see u tube for opening procedure) disconnect the screen leads and replug them, watch out for any static charge or dry joint signs, i did the same and my laptop have recovered and never repeated the problem.....Good luck
    Problem Solver:
  • 7 Answers
Just a thought on this. Is it possible that the fan vents are plugged up and the machine is unable to cool. Now keep in mind the fact that it now it wont boot at all. Overheating of the CPU has limits so to speak. The CPU may be damaged. Bottomline here is................be sure that the fan can vent heat out of your machine.
Posted on Mar 10, 2008
    Sergeant:
    Champion:
  • 310 Answers
Some times its the memory slots trade your sticks around and reboot
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Posted on Jan 01, 2008
Where can I download an owner's manual?
Inspiron 6000 Service Manual - Product Support ' Dell US
www.dell.com/support/home/us/en/19/.../inspiron-6000/manuals
DellManuals & documentation for your Inspiron 6000. Last Revised: 7/8/2013. Manuals.Inspiron 6000 Owner's Manual PDF (1724 KB). More Languages. Deutsch ...
DELL 6000 OWNER'S MANUAL Pdf Download. - ManualsLib
www.manualslib.com > Brands > Dell Manuals > Laptop > 6000
View and Download Dell 6000 owner's manual online. ... Dell owner's manual notebook pc inspiron 6400, e1505 (186 pages) ... NOTE: Corporate, government, and education customers can also use the customized Dell Premier Support ...
Jan 01, 2016 | Dell Inspiron 6000 Notebook
Turned on computer and I got a black screen with
go to bios restart pc press f2, then load defaults
Feb 28, 2010 | Dell Inspiron 6000 Notebook
My Dell Inspiron 6000 (which I think I bought in
Have you tried this:
1. After removing the battery
2. Press and hold the power button for at least 10 sec.
3. Put back the battery
4. Turn it on
if this doesnt work, there could be a problem with your operating system. Try accessing safe mode if you can login .TAP F8 continously on the dell logo screen, and it will open advance boot options. (Just select safe mode) If safe mode boots properly try running system restore to restore it back to the previous date where your computer is still booting to windows. Hope this helps
Dec 08, 2009 | Dell Inspiron 6000 Notebook
My inspiron 6000's power flickers on and off intermittently, switching between A/C & battery power. I've replaced the power cord. Any other ideas?
Try removing batt and use ac adapter alone. Check if laptop works fine also check if LED flickers still.
Try removing ac adapter and use battery alone and check if batt flickers as well.
If flickering only happens when both are connected or vice versa try this first. Update the BIOS for your laptop. Download the BIOS update from http;//support.dell.com
Oct 22, 2009 | Dell Inspiron 6000 Notebook
Replaced inspiron 6000 screen with 6400 screen
the screen is bad just look for something to do about it.
Jul 06, 2009 | Dell Inspiron 6000 Notebook
Dell inspiron 6000
u need to check the same issue using another monitor or a display device if u get the same 4 screen resolution then its the video card or else the issue is with the LCD.
May 15, 2009 | Dell Inspiron 8600 Notebook
Battery icon flickering when plugged in
this is common within your product series. i actually havent seen one that doesnt do that. it either means the battery is dead or the motherboard is bad. and im starting to lean tword motherboard only because this is such a comon problem. and even after people buy new batteries, it still does it. so i believe its your motherboard.
May 10, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron 6400 - Battery replacement
Depends on your use. The 9 cell will hold a charge for about 2 hours, depending on your configuration and the 12 I believe is 3-4.
Feb 21, 2009 | Dell Inspiron 6000 Notebook
Black screen
Try to reinstall XP again, when prompted to partiton, select to do so.
You will lose everything on the hard drive and will need to reinstall all of your programs.
Hope this helps.
Good Luck.
Nov 28, 2008 | Dell Inspiron 6000 Notebook
Problems with Dell Inspiron 6000 Battery ? DELL Inspiron 6000 laptop battery is popular, why ?
You can also pick up the batteries less expensive than most computer places at batteries plus. And yes it sounds as though it is the batteries charge is getting low, especially if it runs fine when the battery is out and you have it plugged in.
Mar 13, 2008 | Dell Inspiron 6000 Notebook
Dell Inspiron 6000 Notebook Logo
231 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
