Question about Panasonic PT-53WX42 53" Rear Projection Television
Panasonic PT-53WX42 The red Convergence just all of a sudden went out of alignment when I changed the channel. The other colors are aligned but the red will not go back into alignment after all we tried. The red does move but not all the way back into alignment
  • Andrew L Jan 01, 2008
    I have same problem with my TOSHIBA65DHX82.. I have tried everyhting with no success. Does anyone have a clue what coud be the problem?? I know the tv has three separate tubes red, gree, blue. Could one of the Tube be out?? HELLLLLLLLLLLLLLLLLLP.
  • 4,402 Answers
Convergence IC bad
Posted on Jan 01, 2008
Colors are not aligned
Can't use the flash focus button or the convergence control crosses +s don't alignes red,blue,green colors.The tv have convergence problems,it dead.Must replaced 2 STK convergence ICS,and some or all it resistors to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 07, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic 53" tv
Blue background lines with colors otherwise OK may be a loose or dirty blur drive potentiometer on small circuit board behind front grille and beneath front imerboard cover. These are hot-glued in place from factory but may be the cause f the problem. They're VERY sensitive.
If you have bowed blue lines instead of properly aligned colors, you probably have a blown convergence amplifier IC. These boards are no longer available so yours will have to be repaired. Some shops repair them but many send them out for 6-10 weeks. Fairly expensive too considering the amplifier chips are about $35 each (x2).
Jun 01, 2009 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic red and blue picute
you need to replace both the convergence Ics they are STK392-110 you can get new replacement ICs at the following link and they provide free instalation instructions. heres the link.
Jun 07, 2008 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic PT-53WX42F Picture Problem. Color Distortion.
Your TV most likely has a Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site They have put together convergence repair kits for most models.
The kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, etc. Everything you will need to do the repair yourself.
Dec 03, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Panasonic 47wx42f projection
It sounds like your may need to replaced your convergence ic's loc# ic7001 and ic7002 stk392-110. That should take care of your alignment problem.
Blue color gun off line
What are you referring too when you ay the blue color gun is offline? Is the blue crt not lighting? Or just the convergence alignment off??
Nov 23, 2007 | Panasonic PT-53WX53 53" Rear Projection...
Convergence IC's must be replaced = requires chassis pull...
A repair normally done by skilled technicians ......T.
Nov 16, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Green horizontal deflection
Change both STK convergence IC's for reliability. They amplify/control both horiz and vertical. re-align after replacement.Locate them on the largest heat sink in your set!
Sep 26, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Color guns out of alignment
It sounds to me like the convergence amps themselves have failed. Ic7001 and Ic7002, both are STK392-110 Sanyo built Ic's and not an expensive job for a qualified shop. When shopping around for a shop to repair it ask what they charge for replacement of the convergence amps in this unit. And take the unit to them to save pickup and delivery charges...
Have a great day!
Dec 21, 2006 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-53WX42 53" Rear Projection Television Logo
112 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
