The two units are in different rooms, they both will run 5-8 mins. and cut off.8-10 mins cut back on. room temp is stayinf the same, but i did not think they should kick on and off so soon.
Make sure there is nothing in front of the units, Chair, Couch ect, if you take the cover off the Units, you will see a little black Thermoster attached to the coil.
If the air bounces back off of something then it will cool that Thermoster and shut the unit down before the desired room temp is acualy reached.
Also make sure your Thermastat control knob is turned far enough to the right so that its asking for more cooling, Or desired temp.
Hope this helps.
Good Luck!
Was this helpful?
Yes
No
Popular Solutions for GE Zoneline Deluxe AZ25E07D3B
Works fine on cool; on heat it puts out hot air for a minute or two and then gets stuck in a...
(More)
Works fine on cool; on heat it puts out hot air for a minute or two and then gets stuck in a defrost(I guess) cycle with a strange noise from the evaporator/fan (inside) unit. It is a Rheem branded product I think the salesman said was made by Goodman when installed about 3-4 years ago.
Conia 3 HP, 5 yr old air conditioner/ had split system outdoor unit serviced recently, re-gassed,...
(More)
Conia 3 HP, 5 yr old air conditioner/ had split system outdoor unit serviced recently, re-gassed, some leak fixed/ internally wall unit discharges droplets of water that seems to drip through front cowling , and fall to carpet.Droplets of water can be felt being thrown out by the fan ...it seems wet through to the louvres. Water condenses on any day , humidity , or temperature level.
unit will not do anything, remote thermostat show no display. diconnected remote thermostat, unit...
(More)
UNIT WILL NOT DO ANYTHING, REMOTE THERMOSTAT SHOW NO DISPLAY. DICONNECTED REMOTE THERMOSTAT, UNIT STILL WILL NOT DO ANYTHING. HAS POWER.
