Question about Speed Queen AWS52NW Top Load Washer
Bearing or gearbox noise on spin
This post is a bit of a "Hail Mary".
I am in Australia and the machine is a Model LWK74 manufactured by Speed Queen and marketed by Kleenmaid in this country. It was bought in 2000. The AWS52NW is the nearest American equivalent that I have been able to find. (corrections accepted).
The problem is a "dry bearing" type of noise when the machine is in spin cycle. There is no noise during the wash cycle. It appears to be coming from either the top bearing just under the bowl, or the gearbox. There is also a leak from the tub seal. I know I am going to have to call the repair guy but I want to learn as much as I can about how this machine comes apart so that I can be sure I am not being ripped off. These guys charge like a Malley bull. (Thats Oz for wild bull).
The amount of information available in Oz on the internal details of this machine is zero, zilch, nada, NOTHING!!
If anyone can provide me with the correct equivalent model number it will make my search easier. Also, any other advice would be gratefully appreciated.
I await your reply with baited breath and offer my thanks in advance
  • rmkthandyman Jan 02, 2008
    Thanks for your response. I kinda figured what the fault was and its cause. It will be interesting to see what kind of estimate I get from a local repairer.
  • 447 Answers
It is a pleasure for me to offer some assistance to users all over the world. The problem you are describing to me is a very common for any amana, speed queen washers. The tub seal leaks and washes the lubricant from the upper bearing making the roaring noise in spin. The bearing needs replacement now, also the tub seal comes as a kit to rebuild all the sealing surfaces. It also does require a complete dissasembly to install the new kit plus the bearing. I would charge 3 hours labor @ 75/hr and the parts would be around $100 for the hub-n-seal kit and the bearing. However you may want to consider a new machine with a better warranty (extended warranties are a MUST these days......BUY ONE with any new appliance. Hope this helps let me know if you have any questions. Unfortunatly these Speed queen design washer have a myriad of design problems and this is only one of them.
Posted on Jan 01, 2008
Kleenmaid Model LWK74 has water leak directly under front of machine. Leaking during last stages of washing cycle.Sometimes it does not leak so bad and depends on size of the load washed.
Posted on Dec 29, 2009
Why does a front loading lg washer smoking in spin cycle
Lg washer smoking - YouTube
? 1:06
Mar 29, 2013 - Uploaded by mrsbarney04
Lg washer smoking ... LG Front-Load Washer Disassembly -Washing Machine Repair Help ... Lg Washer model #WM2016CW PARTING OUT! ... Roblox: Chaos Washers -SPINNING IN A GIANT WASHER WITH FANS!
GE Washer Diagnostic - Loud Noise and Smoking ...
? 2:33
Jul 7, 2013 - Uploaded by
Service your trusty GE Washer that has these following dilemmas: Loud Noise ... L-G. Samsung Kenmore ,LG, Whirlpool, Electrolux Speed Queen, Amana ... Front Load Washer Repair - Bearing and Seal Failure Mode - Duration: 14:44. ... WasherDiagnostic - Very noisy during spin -GE, General Electric, ...
LG WM1815CS Front Load Washer Smoke burning smell ...
Jan 25, 2016 | LG Washing Machines
Fix agitator on a speed queen awm290
Is the drive belt in good condition?
Does the machine spin dry?
Is there water leaking from the bottom?
I suggest the gearbox needs to be replaced. Another sign is if the machine is noisy when it is washing (agitating)
Jul 04, 2014 | Speed Queen AWS45NW Top Load Washer
Grinding/whining noise from gearbox/final drive - fiat 500C Lounge - 2010 model
I think removes the tyre both then check its gear box bearing noise or clutch plate bearing noise
Dec 16, 2013 | Cars & Trucks
Oil is getting into wash water
Hi Bob just read your posting.I am afraid your gearbox is leaking oil into the water .This means to repair the machine your gearbox needs reconditioning or replacement and also the main shaft seal will need replacing.I am putting this posting as a clarification request because my brand of expertise is FISHER@PAYKEL but I have some experience with SPEED QUEEN and KLEENMAID,which are the same machine only different names.Posting this reply as a clarification request will still leave your posting up in the washing machine area for other experts to hopefully help you further.But I am 100% sure that your gearbox needs repairing.Please reply if you need further help or information from me.Good luck.<br />
Aug 28, 2010 | Speed Queen Washing Machines
Machine making loud noise on spins cycle
Well, the only time the washer (speedqueen) is noisy on spin is if one or both the bearings are faulty. Normally when you get a leak, it means the hub/flange and seal kit need replacement and this also includes the top bearing because when soap suds leak past the seal assembly it drips directly onto the bearing. The acidic properties in the soap suds eats the grease in the bearing which ends up becoming defective. One can also get an anoying squeek if a bottom base gasket is worn or removed. This would be audible even on wash cycle.Conclusion, check the bearing on top of gearbox.
Jul 21, 2010 | Speed Queen AWS44NW Top Load Washer
Speed queen top load washer does not agitate properly
you need to see if the motor turns one direction during wash and the other during the spin. If so, your gearbox is faulty and needs replacement. If motor only goes in one direction at all times, then very possible, the timer is faulty.
May 29, 2010 | Washing Machines
Making noise when spinning
HI there.This sounds like the centre bearing & seal are worn causing noise & water leak.It's normally called a Hub & Seal Kit.It is quite an involved job & without the right tools it would probably cost somewhere around $300 upwards to have repaired.Very good quality machine & worth while repairing.Try to avoid useing the machine until repaired as you could cause electrical short due to water leaking.
May 28, 2010 | Speed Queen AWS44NW Top Load Washer
Speed Queen AWS52NW Top Load Washer Logo
1,729 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
