IBM speakers I am not sure what mo# they are. one is stampped 6292.... Date of manufacture ???? They have bass-treble-volume controls on front of left right spkr. on back it has (from top to bottom) audio in, sub, left, 12v dc. The question I have is if I can find just a sub do I need a stereo or mono end on it and does it need to have an amplifier in it or does theese speakers provide this ? Help me please, Mike
  • 51 Answers
Yes this speakers provides stereo and mono but we have adjust an additional cricuit to work properley...
Thank you,
Posted on Jan 01, 2008
Peavey Fury 4 Quilted Bass guitar serial number 01050957
This is from the Peavey website. It indicates a date between 2001-2003. I found a date from another source indicating 2003. They Fury IV is a nice instrument!
"Offset double cutaway solid body, 21-frets, Quilted Maple top, solid maple neck with rosewood fingerboard, two VFL internally-active pickups, 3-band active EQ, single master volume, mid, bass, and treble controls, satin chrome hardware, available in Trans. Red, Trans. Blue, Trans. Green, or Sunburst finish, 34 in. scale, mfg. 2001-2003"
There is further info available from Peavey: http://www.bluebookofguitarvalues.com/Electric_Guitar_Values/Manufacturers/PEAVEY/Categories/ELECTRIC_BASS__FURY_SERIES/Models/FURY_4_QUILT_TOP?id=PEAVEY_ELECTRIC_BASS_FURY_SERIES_FURY_4_QUILT_TOP
Apr 10, 2014 | Peavey Music
Where can I find a satellite speaker that controls the sound?
For the most part volume is controlled on computer, though speakers may have separate volume \ bass \ treble controls. Or, are you looking to purchase?
Aug 31, 2012 | Harman Kardon SoundSticks II Computer...
On a speaker on the computer what does the things mean? those nobs
Depending on the speaker versions, it can have a couple or several knobs. One to the left usually controls turning on the speakers and also controls the volume. The other knobs usually control the Bass and Treble sounds coming from the speakers. If you get more specific and give the actual brand, model I could tell you exactly what each is for.
Hope this helps.
Dec 23, 2010 | HP Compaq Computer Speakers
Hi there I have an RAB030F clarion stereo in the car i just bought and no one can figure out how to change the time...any suggestions?
Setting the Clock
:$To turn the Power off, Press the POWER button ,) press and hold the BAND button a,wh ile
again. pressing the Function button 1 a to enter
2) Use the Up and Down buttons to adjust the clock display mode.
the volume. 2) Press and hold the BAND button m, while
A : Increases the volume. pressing the Function button 1 for 2 sec-
V: Decreases the volume. onds or more. This enables clock editing.
,#A Ci'4UTlOM
Audio Mode Adjustments
1) Press the AUDIOMODE button to select
the adjustment mode. The mode switches as
follows each time the AUDIO MODE button is
When this unit is turned on, starting and stop- pressinq the Function button 1 at the same
pressed:
BASSrrREB + BAUFAD -B Previous mode
2) Use the Left and Right and the Up and Down
buttons a, to adjust the bass and treble.
-=Adjusting the bass>
bb : Bass gets stronger.
4: Bass gets weaker.
-=Adjusting the treble:,
A: Treble gets stronger.
V : Treble gets weaker.
3) Use the Left and Right and the Up and Down
buttons a, to adjust the balance and
fader.
<Adjusting the balance>
W: Sound from right speakers gets stronger.
44: Sound from left speakers gets stronger.
<Adjusting the fader>
A: Sound from front speakers gets stronger.
8 : Sound from rear speakers gets stronger.
*The editable fields will be indicated by flash.
3) To move between the hour and minute fields,
use the Left (hour) and Right (minute) buttons
a.
4) To.store the clock setting, press the BAND
button a.
Aug 16, 2010 | Clarion RAB030F
Can't adjust bass and treble
The only adjustments available on the unit are Volume and Bass (Subwoofer Level). There are no Mid-Bass or Treble adjustments.
Sep 20, 2009 | Jasco GE 98903 2.1 Speakers
Help
Hi Cassie, unless your receiver is a surround reciever, it won't have an actual subwoofer output. The good news is that you can use either a "line out" jack or a "tape out" jack instead, which most receivers do have. These jacks always have the signal, so there are no special settings to remember - simply operate your receiver as usual. Everything comes out of these jacks, not just the bass - but it won't matter since your subwoofer will only reproduce the bass frequencies. The bass information is generally identical in both left and right channels, so either the right or left jack should work fine, and it's okay to leave the other one unconnected. The only bad thing is the line and tape outputs are not affected by the receiver's bass and treble controls, so you'll have to control the bass volume at the subwoofer if it has a control. If you can't control the amount of bass you hear, turn up the volume and reduce the treble which will give the illusion of more bass. I'm assuming you have "powered" subwoofer (has its own built-in amplifier). Good luck!
Jun 22, 2008 | Bose Acoustimass 15 System
Troubleshooting on Adjusting Treble/Bass
Look in your owners manual and make sure you are turning the right knobs or pushing the right buttons once you have the adjustment screen for the bass/treble showing. It could be that they use different knobs/buttons than the volume control. If you are using the right controls, then you have a problem that only a shop can fix. You might reset by taking away all the power (acc and bu) for a couple minutes and then reconnect, but if that doesn't help then it time to go to the shop.
Aug 10, 2007 | Alpine CDM-7861 CD Player
56 people viewed this question
 Grubhead
Grubhead
