Air conditioner My remote control does everything but register with the sensor on the actual conditioner.I can fire it up manually but the remote wont switch it on or off or respond at all. I have new batteries inserted in remote and display on remote is working OK. Can you help please?
  • 236 Answers
Some some remote control have RST or RESET button, you have to push this every time you change the battery or for malfunction remote control. You can find this either in front of remote control or at the back of the remote in battery compartment.
Posted on Jan 01, 2008
I have an air/heat window unit that wont heat good and wont let me change fan speeds what can be the cause
Hello friend, thank you for your post!
Based off the information you have provided your Frigidaire air conditioner, FAZ08HS1A, is not heating up or changing fan speeds. From what you are describing it sounds like a potential problem with the control board or sensor. I would suggest performing a reset on your air conditioner and you can do that by disconnecting power from it for ten minutes. Are you under warranty? I would consult with the manufacturer for further resolution regarding your air conditioner. I hope this information has been helpful. -Matt
Sep 24, 2014 | Frigidaire Heating & Cooling
Fujitsu aircon AOT30ABHL 12 year old wont start using remote new battery
its a common problem. it could have either short circuted or the sensor is ********
Oct 31, 2012 | Fujitsu Heating & Cooling
Cannot turn unit on with remote
the problem lies between the remote sensor of the unit or the remote control itself.
You need to test the remote with another unit or test another remote with the unit to actually confirm where the fault is coming from.
Jan 05, 2012 | Sanyo Split System Air Conditioner
Panasonic inverter air conditioner remote control wont work, it will not turn on and there does not seem to be an override switch on the actual unit?
to replace your battery have 2 AAA batterys and slide down the front cover and pull the cover of the remote you will find the battery compartment underneath the slide.
Dec 31, 2010 | Panasonic Heating & Cooling
Fujitsu air con unit. Remote wont work. has new batteries
Check the micro processor control whether it is in manual mode or not. If not check the sensor whether it is functioning or not. If everything is fine then remote control has to be changed.
Aug 15, 2009 | Heating & Cooling
Remote is working- but unit won't turn on
check your remote control using your camera or cellphone camera as your eyes. Point the remote control transmitter to your camera and "on", light should emit in your remote control transmitter (means good remote). Check for reset or rst button in your remote control and push it to reset and test it in your unit. If wont work means either the receiver board or mean board is defective.You need a qualified tech. for this problem. For the mean time you can use manual button to operate the unit.
Jan 30, 2009 | LG LSC121PMA Split System Air Conditioner
Remote's functions dont control the air con anymore.
Have you checked the battery's in your remote?
Jan 30, 2009 | Heating & Cooling
Kelvinator Split System Air Conditioner not turning on.
On some remotes there is a reset button which is pressed by using the nib of a pen. Or if this does not work you should look under the cover for a manual button, most units have one, and see if the aircon responds. I suspect your remote sensor is faulty, but try the previous suggestions first.
Jan 18, 2009 | Heating & Cooling
Samsung AS12ABMC A/C (about 3 years old)
heres a clever way i use to check remotes are working. put your mobile phone into camera mode and point your remote control toward the camera while pressing any button.if working you will see a blue light emiting from your remote on phone screen.
Jul 08, 2008 | Samsung AS18A6RB Air Conditioner
Heating & Cooling Logo
650 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
