Question about BenQ PB6100 Multimedia Projector
White vertical line on left side of screen
White vertical line showed up. Took projector down and cleaned it. Started the projector again and white line was gone. Took about 5 minutes and the white line returned. Line is about 2 inches wide and is the full height of the picture
  • 2 more comments
  • Anonymous Mar 12, 2014
    my acer projector start flickering after 10 minutes and even show vertical lines
  • Anonymous Mar 14, 2014
    optima EP1690 projector has vertical white lines
    i wanted to show pictures on my projector and there are vertical lines showing on the screen.i have only used it a couple of times. how can i fix the prblem?
  • 563 Answers
Hi there
This problem can only be fixed properly by replacing the Mainboard.
Posted on Apr 01, 2008
2 Suggested Answers
SOURCE: White vertical line on left side of screen
omg, I just figured out why OUR projector was doing this! There was an adaptor plugged into it that we use to hook it up to cable to watch games/tv shows sometimes...once I unplugged that from the projector the lines dissapeared!
Posted on Oct 02, 2008
NP50 has white vertical stripe down left side of screen
Display is faulty, I would say. Prove it with an external screen.
Mar 06, 2014 | NEC Office Equipment & Supplies
Vertical white line in the middle of rca tv
Check and replace all the electrolytic capacitors at its vertical output section circuit.
Mar 17, 2013 | Televison & Video
Half inch crystal/ solid white vertical line on screen
Adjust the horizontal in the menu then try the overscan adjustment. If the image does not look dim you do not need a lamp.
Jun 04, 2010 | InFocus IN72 Multimedia Projector
When using the ADF for scanning to pdf, it creates black lines vertically down the left side of the document. If I use the flatbed scanner, no lines.
Your machine ADF is dirty or dust in adf glass please clean it by soft cloth and scane again its clear and sharp.
thanks.
Nov 24, 2009 | Brother MFC-7820N Printer
White Vertical line in the screen.
Again, this sounds like a light tunnel failure. See my other post about this.
I replaced my light tunnel with square brass tubing I picked up at the hobby shop.
Sep 21, 2009 | InFocus ScreenPlay 4805 Multimedia...
I had a smililar problem after taking it apart i realised that i had screwed my mount skrews into the video main board and cracked it along with a few soldered wires, if you havent done any physical dammage to it try a firmware upgrade
Jan 20, 2008 | InFocus IN72 Multimedia Projector
White vertical line in the center of projected image
I have a Dell 2400MP projector that had the same problem of vertical white lines appearing over the screen.
This may seem like a simple solution, and I don't know if this will work for you, but the way I solved the problem was simply to press the bottom side of the projector, until the white lines disappear . Until now, the problem has yet to resurface.
Here's some simple steps:
1. Turn on projector
2. Connect projector to computer
3. Focus projector
4. If white vertical line appears, firmly press underside body of projector
5. See if vertical white line disappears
6. If not, try slowly pressing other parts of the body of the projector and see if white lines disappear.
7. If solution doesn't work, you may need to send it to the service center.
Hope this solution works for you.
Best Regards,
Ghazali Ridzwan
http://www.ghazaliridzwan.com
Nov 28, 2007 | ASK Proxima Proxima DP2000S Data Video...
White lines across the screen
Sometimes if the resolution is set too high, white lines will appear.
Dec 12, 2006 | Toshiba TDP-T9U Multimedia Projector
BenQ PB6100 Multimedia Projector Logo
2,515 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
