IT involves getting at the chips as the KP51WS510 uses two of the STK-392-560 CHIPS.
Each chip has about 18 pins that have to be unsoldered and then both chips replaced--most of the time you just need to replace both chips and adjust the set with the Sony remote--sometimes there will be another bad part around them taken out but this is not real common on these sets.
Can you solder? Are you handy if I tell you how to locate the chips and get at them?
I have repaired hundreds of sets with convergence problems.
Confirm actual model number to me and tell me if you think you can do it---if you know how to solder etc I can tell you what you will need and how to do it.
sony kdp 57w5550 timer light flashes 10 times then pause then 10 more is it worth fixing , was...
(More)
sony kdp 57w5550 timer light flashes 10 times then pause then 10 more is it worth fixing , was working, turned it off 30 min now nothing
