Either the power source, battery, power adapter, or power jack is faulty.
1. Power source - if connected to a power strip, flip the switch. Move to another outlet.
2. Remove the battery (disconnect cables, flip laptop, unlock and slide out) and try to power on with just the adapter. If it works, battery is faulty.
3. Power adapter to laptop is faulty. Replace. If you have an identical system to test (and it needs to be identical), try on another laptop.
4. Power jack - repair power jack (may need to be serviced).
My HP dv9000 will not boot up. Begins to start, but screen black and keys appear not operating....
(More)
My HP dv9000 will not boot up. Begins to start, but screen black and keys appear not operating. Occasionally, will finally boot after powering down and back up
TVAgent.exe entry point not found always pops out. It says: "The procedure entry point...
(More)
TVAgent.exe entry point not found always pops out. It says: "The procedure entry point PowerReadACValue could not be located the dynamic link library POWRPROF.dlll
I have a 3 yr old HP dv9205 17" monitor.... It will not start up... Begins powering up...blue...
(More)
I have a 3 yr old HP dv9205 17" monitor.... It will not start up... Begins powering up...blue lights all come on for about 20-25 seconds..nothing on screen... then shuts down...and begins cycle again....will do so until I interupt the power Is this a mother board...or hard drive problem? HELP!! Matt
