Mustang Rzt 50" Zero Turn Riding Lawn Mower
Problem for Mustang Rzt 50" Zero Turn Riding Lawn Mower
How do i get the drive belt over the engine pulley
By kiley_cirill on Oct 26, 2009
how do i get the drive belt over the engine pulley
Best Solution
posted on Oct 26, 2009
Very Helpful)
mrfixit-jerr
Rank: Guru  Garden Tools  Expert
Rating: 94%, 7585 votes
* If you don't have a parts list, go to the Sears website. They offer them there. It should show in one of the sketches how and where the belt needs to be routed.
Step 2
* Then go to a sears repair with your old belt and part number and buy a new one. Make sure you compare the belts to each other to make sure they are the same.
Step 3
* If you have a newer mower, there should be a decal on the mower deck showing how the belt is routed. I can't say exactly how to route the belt since I don't know what mower you have. Ours had the decal and there was a sketch in the manual.
Step 4
* Loosen the keepers at the drive pulley and pull the belt down and off.
Step 5
* You may have to disconnect a side of the mower deck.
Step 6
* Slide the belt back on as per routing instructions.
Step 7
* Put the belt keepers back exactly how they were before.
Step 8
* Watch out for idler wheels and make sure the belt is on the correct side.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Mustang Rzt 50" Zero Turn
Questions and Unsolved Problems for Mustang Rzt 50" Zero Turn
Do you recommend Mustang Rzt 50" Zero Turn Riding Lawn Mower?
Answer
Answer
How do I attatch the heavy spring that helps lift my snowblower to my 416-8 toro snowblower
Answer
the discharge chute does not stay in place when turned. When I tok it apart, the bearing and spring... (More)
Answer
how do i attatch my snow blower to my simplicity 5216H lawnmower. the man said the blower would fit... (More)
Answer
when I try to turn either way, it doesn't want to turn, I hope that this a belt problem
Answer
how to replace drive train belt on mustang rzt by troybilt
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Riding Mowers... Experts
Top Garden & Power Tool Repair
(800) 937-7279
Replacement lawn mower and snow blower parts from...
Commercial Parts Warehouse
(509) 678-4379
Precise Engine Repair proudly represents Briggs...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
