Question about LG Projection Televisions
LG RP-57NZ60P Rear Projection TV - alignment
Hi, hopefully a simple one. I've got an LG RP-57NZ60P (its made in Mexico April 2004) that's in great knick, shows a decent-ish picture but at the bottom of the screen the colors seperate into red blue and green. I'm wondering if there's a simple way to realign the system myself.
  • 4402 Answers
SOURCE: Hitachi HD projection TV-red and green wave and alignment problem
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
Posted on Dec 05, 2007
SOURCE: LG Rear projection tv help... Red, Blue and Green horizntal line through screen.
The complaint may be dry solderig or yoke ,horizontal or vertical oscilator
Posted on Dec 31, 2007
SOURCE: 52" LG LCD rear projection screen blue discoloration
bonsoir!ce que vous avez ici c'est un probleme de light engine ;c'est surement un le filtre bleu qui est brule et cette tache va remplir tout l'ecran apres,il faut contacter lg et manifester parceque le light engine coute tres cher 900 us
Posted on Oct 18, 2008
  • 2920 Answers
SOURCE: samsung rear projicton tv 42 inch aa68-50523a
youll need to have the tv converged...the red being out of line says that
Posted on Nov 05, 2008
  • 3459 Answers
SOURCE: Sony KP-51WS500 Rear Projection TV colors are distorted.
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Posted on Mar 13, 2009
  • 69 Answers
SOURCE: Sony rear projection widescreen TV. Concave shapes & ghosting
sound like the convergence ics have failed
Posted on Feb 07, 2010
0 characters
1 Points
LG Model RP-60SZ30 part number of lamp.
Send email to, he might has that model
Feb 22, 2013 | Projection Televisions
Hi i want to ask about a lamp that related to thomson tv thomson 61 dsz 644 dlp hd tv lamp what is its price ?
Mar 09, 2011 | Thomson 61DSZ644 Rear Projection Lamp...
Tv projetion lg model rp-60sz30
You need a new bulb. It's easy to install. Remove the lower panel. Remove the 2 screws that hold the buld casing. Remove the bulb and replace with a new one. Replace the screws then the lower panel.
This will save you about $300 in so called labor.
Sep 17, 2009 | LG RU-60SZ30 60" Rear Projection...
LG rear projection colours out of alignment
I have a similar problem with an LG (except my red is the one that is fine) and was able to talk to a tech in some detail about it. The tech prefaced by saying that he had done a hundred or so of these with exactly the same issue. This is very common and the life span of rear projection televisions is not great. Having said that, plasmas and LCDs are also limited in life span mostly due to modern high performance gaming machines which shorten the lifespan of monitors both plasma and LCD alike.
From what I have gathered, this is not a problem that you can easliy sort out. (Of course they would say that though) It involves replacing the digital board which means soldering followed by aligning the lamps which requires quote a lot of expertise.
The part itself apparently costs around $200 Australian and the labour will vary for the cost of the technician but I was quoted that the labour was about the same cost as the part.
Not sure if I would call this solved but I hope it has been at least a little helpful.
May 26, 2009 | JVC AV-56P575 56" Rear Projection...
Green out of alignment on samsung rear projection tv
LOOK for 3 parts that start with STK (BLACK THINGS THE SIZE OF A MATCHBOOK) then replace all 3 (ebay) also look for some green coils that may be burned. If you SEE THE STK's then your in luck, as 95% of them are bad.. Please rate!
Mar 30, 2009 | Samsung HCL4715W 47" Rear Projection...
Have heard that it's a common problem, there's an issue with the optical block. Sony is susposed to be aware of the problem & has exptended the warranties on some models or offers gift cards towards the purchase of a new tv, depending on how hard u push once u get someone on the phone.
Aug 05, 2008 | LG RU-60SZ30 60" Rear Projection...
Pioneer 58" SD-582HD5 1080i -Rear Proj TV
Like most problems with this model, check and re-solder the connections on the power supply board on the right rear of the tv, just behind where the main power cord goes in. Most problems are around the upper left corner where the white connectors E-12 and others. Check all of them from loose and cold solder solder connections on the board. Hope this helps.
Jun 02, 2008 | Pioneer SD-582HD5 58" Rear Projection...
Thompson rear projection tv 44" Misty picture
Remove cardboard back ... clean RGB lens caps with soft cloth
That's it ! Should be nice improvement......T.
Nov 28, 2007 | Mitsubishi VS-55705 55" Rear Projection...
Mitsubishi pin and barrel issue
PVAT!Check for CRT coolant leak on PCB's. SOLDER ANY/ALL BAD CONNECTS. Replace convergence IC's,re-align.
Aug 28, 2007 | Mitsubishi VS-60609 60" Rear Projection...
Mitsubishi rp vs 70707
Do you know if this is what the problem is? If its color problems or convergence alignment then:1. THE CONVERGENCE CAN BE RESET BY PRESSING "MENU 12596" TO ENTER THE CONV MISC. MENU THEN "8970" TO RESET.
Jul 28, 2007 | Mitsubishi VS-70707 70" Rear Projection...
Projection Televisions Logo
179 people viewed this question
Top LG Projection Televisions Experts
Steven Wander
Steven Wander
Lawrence Oravetz
Are you a LG Projection Television Expert? Answer questions, earn points and help others
