This is one of several models that had a common problem.
If set comes on with sound and you after a minute or two see a faint odd band of noise top to bottom on the screen to the right side C509 which is a .047 cap at 200 volts is bad.
Cap is seen in attached photo(location marked and cap here gone).
The cap when you locate it from the C509 number which is on top and bottom of board may have a crack or not---it is the cause of this problem.
There is a hard way and a easy way to get at it--let me know and I will explain.
3.00 part....................
Pencil is point to location on Right side board seen from right side.
There are several brown caps here and some plugs here are removed.
I would not try operation of the set in this condition too long.
