Question about Maytag Neptune MAH5500B Front Load Washer
Mah6500 maytag is leaking
I have notice a little water under the washing machine. maytag mah6500.
i have checked the areas under the machine but i cannot detect where the water is coming from. looks like it is coming from somewhere in the front of the machine.
my e mail is clarktl1@cableone.net
  • Anonymous Mar 16, 2008
    inner drum has rubbed a hole into the door inner liner
Us too are having the same problem - and recently - it has been filling with water on its own - and not emptying!!! We have had major floods!!
Posted on Jan 05, 2008
MY maytag washer is leaking water from bottom of machine - the repairman said there is a hole in the door - please advise!!!
Check your rubber boot connecting the tub to the machine, it will fail. If you find no hole in it and have a drain in the bottom of boot, then pull front panel to see if drain tube is broken. If thats not broken, everything else will be visible as far as drain lines etc, just look for signs of leakage.
Jan 19, 2010 | Maytag MAH6500 Neptune Front Loading...
Order/Replace Rubber Boot on Maytag Washer?
it can be quite tricky to fit, you can buy one,I would however advise to get a supply/fit quote from an engineer as he will get discount on the part, unless you are good diy person ,get hired help....
Nov 28, 2009 | Maytag MAH6500 Neptune Front Loading...
Maytag washer MAH6500 leak - door boot issue?
there is a drain hole at the very bottom of the sump
about 1/4 in
if you ahve any other holes you will need a new boot
there is no real way to patch them, most patches will not flex enough to stay in place
ive included the part number you can order from sears
22003070
the best way to get one over on sears is to order it
then you cazn either fix it kinda hard but id walk you through it
or when the part arrives shedule service, just tell them its leaking
only when the tech gets there tell them you have a boot
sears hates self diagnostics and you will go to the bottom of the list
Oct 07, 2009 | Maytag Neptune MAH6500A Front Load Washer
Maytag Washer leaking from the bottom
It will be the normal trial and error. Remove the top lld and the back panel.statt the wash again and start looking for anything obvious. Start from the soap box, then carefully look down the sides and then if nothing seen, switch machine off and tilt machine untill you can see the underneath. Look for any areas where there is water .(when visible start looking a little higher untill you find the spot.) Most of the underneath areas are likely rust spots that have broken through.. On occation the pipes are perferrated and have a small leak. All observation.
Sep 23, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag top load washing machine leaking water from bottom
The machine is leaking water from the bottom, I think the leak is in the area near where the motor is mounted. Before we noticed the water comes from underneath the washer, we smelled like burning rubber.
Al Bana
Jun 26, 2009 | Maytag PAV2300 Top Load Washer
Neptune washer
check arround the rubber bellows that the door seals aginst, maybe a hole in it, could be a pump leak drain hose leak
a lot of could bees i know but one of these
Apr 09, 2008 | Maytag MAH6500 Neptune Front Loading...
Leaking water Maytag Nepture washer MAH400AWW
open door and feel around the rubber bellow possible tear causing leak
Feb 27, 2008 | Maytag MAH6500 Neptune Front Loading...
Maytag 6500AWQ
The outer tub bearing. This bearing is under a lot of stress and tends to wear out. Check and see if there is excess play in the drum. Move the drum all around. Also if you remove the back panel plate you can access the main pulley. If this pulley has any side-to-side or top-to-bottom play then the bearing is bad
Dec 29, 2007 | Maytag MAH6500 Neptune Front Loading...
Maytag Neptune MAH5500B Front Load Washer Logo
94 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
