Question about Microsoft Xbox 360 Console
Disc tray wont close. Used to be tray would not open. Red power lights flashing.
  • Anonymous Mar 13, 2008
    disc tray will not close,it will close but then open without pressing any buttons.
    Problem Solver:
  • 12 Answers
Your drive either has dust clogging it or it's burning out.
Posted on Jan 01, 2008
416b-4174-b680-0f00-c000-0034
I had this error code as well. Here's the solution that ended up working for me:
  1. Eject the disc tray and remove any disc from the console.
  2. Important: Do not close the disc tray. Leave it open.
  3. With the disc tray open, remove the power cord from the back of the console.
  4. Gently push the disc tray about half-way back into the console.
  5. Plug the power cord back into the console.
  6. Push the power button on the console. The tray should close the rest of the way, then the console should restart and display the Xbox Dashboard.
  7. Important Do not use the controller or the disc eject button to turn on the console.
  8. Try updating your console software again.
What this does is put the DVD drive into Mode-B, which is an alternate operating state that allows the drive's physical memory banks to be flashed with new firmware. Because the latest XBL update involves flashing the drive with new firmware, you may need to physically put the drive in Mode-B. The latest update flashes the drive to make it compatible with Microsoft's new high-capacity disc format, XGD3, which will be used sometime in the future.
Jun 10, 2014 | Microsoft Xbox 360 Console
416B-4174-1601-0300-C800-0036
here's the solution that may work for you
Xbox 360 elite wont turn on no lights power cord lights up
Hmm... it seems it's a problem with the power adaptor. Have you tried to replace it?
Mar 23, 2013 | Microsoft Xbox 360 Elite Console
I put a disk in and there was already one in now it wont eject
The disc tray does not eject when the OPEN/CLOSE button is pressed. Solution
sp.gif sp.gif Follow the steps below to troubleshoot this issue.
    IMPORTANT: The disc tray will not open while a disc is loading; this is normal operation. If this is the case, wait until the disc is finished loading before pressing the OPEN/CLOSE button to open the disc tray.
  1. Make sure the disc tray is not locked; if necessary,
  2. Perform a power reset.
    1. Press and hold the POWER button for 10 seconds until the BD player turns off.
    2. After the BD player turns off, press the POWER button again to turn it back on.
  3. Attempt to open the disc tray by pressing the OPEN/CLOSE button on the front of the BD player.
  4. If the disc tray still does not open and a disc is stuck inside, follow the steps below to force the disc tray to eject:
    1. Turn off the BD player.
    2. Turn the BD player back on.
    3. Immediately after POWER ON is displayed, press the STOP button on the front of the player. IMPORTANT: Only use the STOP button on the front of the BD player. The remote control cannot be used for this operation.
      NOTES:
      • The disc tray should eject and the BD player will turn off. If it does not eject, repeat steps A-C.
      • It may be necessary to press the STOP button in step C two or three times.
If the issue is still unresolved, service may be required
Sep 15, 2011 | Sony BDP-S300 Blu-Ray Disc Player
My xbox says its connected to xbox live and it updates but when it gets to the end its say cant process update status code:3080-335a-1380-0500-cooo-0032
I think I had this error code as well. Here's the solution that ended up working for me:
If this solution was helpful, please leave a positive rating!
Jun 19, 2011 | Microsoft Xbox 360 Console
Tray wont open
Power your unit off using the button. when it's off unplug the power source from the back of the XBOX and leave it out for 30 sec. Reconnect the power source and reboot your machine. Try the disc tray again. If it doesn't work try giving it a tap or a solid knock on the top of the case above the disc tray while it's trying to open. Don't drop the machine or try to pry the tray open. If it doesn't open when you tap it then try light pressure on the front of the tray while it's trying to open. (you can tell it's trying to open because the disc status on the screen will say opening...)
Now if the above did not work
Get a straightened paper clip.
Remove the faceplate carefully starting from the indention that you will see on the side
After removing the faceplate, look for a pinhole just below the disc tray.
*There are two pinholes just below the cover of the disc tray and one pinhole below the X and B of XBOX logo.
*You can try any of the three holes
*Pinholes are so small that the girth of the paper clip is the only object that can fit through the pinhole.
Now insert the paper clip into the pinhole then put a little pressure until the disc opens.
If it opens try to close it, if it closes try opening it again, if it wont open the second time then it need to be serviced
If it opens try to close it, if it wont close try nudging the disc to the right and then to the left, if nudging doesnt then it need service
If it wont open after trying all three pinholes - its needs service
It may be jammed or the drive gear stripped.
CALL XBOX CUSTOMER SUPPORT 1-800-FORMYXBOX
If that doesn't work . call Microsoft and they will instruct you on warranty work.
Nov 24, 2009 | Microsoft Xbox 360 Console
DISC TRAY WONT CLOSE... PLEASE HELP !!!!1
the drive switch is broken try to buy a new one and then it should work coz my dad works in the computer part
Dec 07, 2008 | Microsoft Xbox 360 Console
Disc try wont close
i would advise you to send it off
Aug 22, 2007 | Microsoft Xbox 360 Console
Xbox does not read discs.
Getting to the dashboard screen is a good thing but still cannot rule out a bad circuit board or power supply. All the symptoms point to a bad DVD drive but the opening/closing by itself do indicate a problem with the microprocessor. Can you turn the power on and off with the small button?? If not, would definitely suspect bad board.
Aug 16, 2006 | Microsoft Xbox Console
Microsoft Xbox 360 Console Logo
29 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
