E-Machines eMachines Desktop PC Logo
Posted on Oct 26, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need to know where 3 wires go
The wires are from the power button its an emachine w2247 the wires are red/white black/white and green/white
Mike Wallsch
Level 2:
New Friend:
  • Expert 42 Answers
  • Posted on Oct 28, 2009
Mike Wallsch
Expert
Level 2:
New Friend:
Answers
42
Questions
0
Helped
5899
Points
110
The wires should be labeled HDD,POWER, and i think RESET or somthing, just look on the motherboard within cord reach and you should see all three labeled on the motherboard all grouped together.
1helpful
Need to know how to hook up to 220 power supply what wires go where we got a red wire,black,white, and green which is ground can u help?
L1
L2
L3
Neutral
Earth
North America
Black
Red
Blue
White
Green
There is no blue cable in a 220V, so you have only; white, black, red and ground always green colored wire.
Looking your plug frontal side.
Green Ground on top (semi-circle)
black on left
red on right
white on bottom (neutral).
Am replacing an old wall timer with a GE Smart Digital Timer. The old timer had two black wires connected to two black wires from the wall. The new timer however has red, black, white and green wires. I...
I've tested these timers.
Here's what to do:
1) Connect green to bare copper
2) Switch has 2 wires. For now, connect these two wires to timer-black and timer-red. Choose either one.
3) In back of wall box are white neutral wires twisted together and covered with wire nut. Timer-white wire connects to these white neutral wires. This action gives power to time clock.
4) If wall box does not have white neutrals described above, then connect timer-white to bare ground wire. Bare ground connects to neutral busbar in breaker box.
5) Turn on power and click manual override button or switch. If lights turn on, timer is wired correctly. If lights do not turn on, then reverse timer-red and timer-black wires.
I unplugged a red/white blue/white black/white wires that go to power switch i need to know in what order to plug them back in
Just use a digital multimeter and you set it to DC. Then, with the voltages measures, white is negative, red is positive as well as green.
2answers
1helpful
2answers
NEED POWER SWITCH WIRING FOR A EMACHINE T-3095
check on the motherboard there should be a small prints on it near control panel.
Motherboard wiring
Green/wht normally = Reset or Power LED
Red/wht normally = HDD LED
And is the third red/BLACK?
There should be a label on the black pin jumper at the end of each wire.
Does it say anything?
Problem with power connections on emachine T2596
Take a peek at this link,
http://www.duxcw.com/faq/mb/frontpanel.htm
it may assist you in your problem
2answers
Wiring info
Most Mobo's have printing next to the places that are jumpered or pluged into. The ones you need sould be close to the edge of the mobo, that is close to the front {power button} side.
2answers
Need wiring diagram for emachines t2200 motherboard
If you are replacing the power supply and it has 4 pin 12v conector and your motherboard doesn't, just disregard the 4 pin plug. The 20 pin conector will supply sufficient power for the processor. Many of the older motherboards did not have a separate 12v supply for the processor.
2answers
EMachine no power
Ok for a start the power switch is not green and white that is the power led, you need to look for a red and black wire normally marked on the connector and motherboard as pwrsw or pswitch.
if you believe it to be the switch unplug the connector and jump the connection on the motherboard using the reset switch or a jumper, or not recommended but have done this myself many times using a flat blade screw driver very carefully and touch the 2 pins to complete the circuit.
if it doesnt power on then its more than likely it is the power supply but the motherboard being faulty could also cause this to happen.
the problem i have found with emachines is that its difficult to get replacement power supplys
Top E-Machines Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
