SOURCE: Leaking around center spindle gasket of outer plastic basket
There was a hole in the plastic liner tub from the inner metal basket rubbing on it during the spin cycle. I got some plastic cement and put it in there and it willl hold for a little while while anyway. Not a very well designed washer when you look into the guts of the monster.
SOURCE: I need to remove the aggitator to remove the inner basket? maybe?
YOU SHOULD HAVE A SPANNER WRENCH TO REMOVE IT BUT IF YOU HAVE A SMALL MONKEY WRENCH AND ENOUGH MUSCLE YOU CAN REMOVE IT
SOURCE: Washer, front loader, Fridgidaire FWT449GFS1,
Hello, Welcome to FixYa. I suspect you are bang on and indeed it sounds like the rear bearing or spider gear is toast. It is a very involved repair either way but if you think you're up to it ( plus, is it worth it ? ) I can help in whatever manner possible with those frigidaire washers. I'll watch for your reply. Good luck. Regards, Macmarkus :)
