Question about Proview PL713S 17" Flat Panel LCD Monitor
Proview PL913s 19" LCD Monitor (model# 900P) *
For this model I need the plug that plugs into the back of the LCD panel. Its not the light plugs, its the display plug. anyway I was just wondering if you knew of were I could get one of those? If you would e-mail me back please. My e-mail is robbliss9@hotmail.com Thank you
  • robbliss9 Jan 05, 2008
    Ok I'm sorry I didn't explain it right. Ok I took apart the LCD Monitor and behind the LCD part there are 5 plugs. 4 of them are the light plugs on the edge of the screen and then there is one that plugs into the center of the monitor that is the plug I need to replace. I'm not sure what kind of a connector it is. So if you know of where I can get a new one I would like to know and if you know what kind of connector it is.
Does LCD monitor emit UV light?
The monitor use Fluorescent lamps (CCFL) to light up the screen, same kind as used for the home fluorescent lamps, no different, they are just smaller in size and lower wattages. Do you use fluorescent lamps in your house to be Green, if there are conflicting info then they would have banned fluorescent lamps a long time ago and will not be banning regular light bulbs in the future.
May 22, 2010 | Proview PL913S 19" Flat Panel LCD Monitor
Looking for circuit board for a 19in proview lcd monitor
Which pc board are you looking for? Most LCD monitor companies use third party PCB assemblies. Can you get the name and number as printed on the PCB?
http://s807.photobucket.com/home/budm/allalbums
Apr 18, 2010 | Proview PL913S 19" Flat Panel LCD Monitor
Monitor screen is black
bad capacitors on the power board internal to the monitor they need to be replaced.
Mar 02, 2009 | Proview PL913S 19" Flat Panel LCD Monitor
Proview monitor blacking out
i would suggest getting a new monitor you might have made it overheat or your display driver failed.
Feb 16, 2009 | Proview PL913S 19" Flat Panel LCD Monitor
Moniter clicking
check capacitors inside for damage is found replace them
Feb 13, 2009 | Proview PL913S 19" Flat Panel LCD Monitor
Proview monitor PL716s
you ave some blown caps on the vga board replace them and all will be well
Dec 28, 2007 | Proview PL913S 19" Flat Panel LCD Monitor
Open Questions:
See all Proview PL713S 17" Flat Panel LCD Monitor Questions
Proview PL713S 17" Flat Panel LCD Monitor Logo
458 people viewed this question
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
ka4iup
ka4iup
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
