Question about RCA P61940 61" Rear Projection Television
53" rca rear projection tv
My tv has a couple of distortion lines that run horizontally across the screen from time to time while watching tv wondring what it might be there is no discoloring just distortion
  • 33 Answers
Check the following:
1. Make sure it is plugged in a socket that is not on the same circuit that uses radio waves (like a microwave, cordless phone, etc)
2. If you have cable, make sure that you cable is connected properly and that the connections are tight. Make sure that the cable is in good shape.
3. Check any other type of antenna (if not using cable) make sure all connections are secure.
4. If you live in an apartment or townhouse someone might be using a device that causes your signal to be distorted.
Let me know if any of these work.
Posted on May 15, 2008
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as
Mar 02, 2011 | Mitsubishi WT-42311 42" Rear Projection...
Sony rear projection 53" screen
Could be convergence settings?
Feb 25, 2011 | Televison & Video
My sony kp 53v75 projection tv has an issue right now. The screen has lines that run horizontally across the screen that slightly distort the image. They move up and down slowly on the screen, Is there any...
Tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alingments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK comvergence ICS and some or all it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv pictures convergence problems.The shop,will cost like $300-350 for parts and labors.
Nov 22, 2010 | Sony KP-53V75 53" Rear Projection...
3-d Picture
The vertical deflection output chip or associated cirutry including the coupling cap and controls. Some units have vertical output transistors which can short and open the B+ resistor feeding the transistors.
Oct 11, 2009 | RCA D52W19 52" Rear Projection Television
WD-52525 screen is jumping all around with wavy horizontal lines etc.
Good Day;
Keep talking to the factory, it is their product. Best Buy won't replace unless it is deemed not repairable and/or terms of the contract. You purchased the extra warranty because you most have felt that the TV might break down. Well, it did, now use the contract to repair your TV.
Good Luck, big IRISH.
Sep 29, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Black horizontal line moving across screen with PS3
Loose connections in the AV board. Re solder . Did you try in video 2 or 3 ?....But Am suggested re solder AV board and connectors. I hope this help you I am here any time thank you!!!
Jul 21, 2008 | RCA P52926 52" Rear Projection Television
Blue streaks across picture
Can you describe in a little more detail what the symptoms are? Are the streaks thin lines or are they large thick swashes of Blue? Is yur video still visible? Sounds like it may be the blue convergence amps or the resistor tied into the amps. is there anyway you can post a picture of your screen distortion?
Jan 26, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Rca jack input very distorted
This is probably a short in the TV, most likely a ground problem.
Oct 19, 2007 | Hitachi 50UX57B 50" Rear Projection...
Strong red tint with horizontal lines across screen
if you have warrenty, return it. if not, then buya new one...the video fuses are dying...hard to fix it.
Oct 06, 2007 | Akai PT4799HD Rear Projection Television
RCA P61940 61" Rear Projection Television Logo
69 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
