This could also be a setting. If you are using component video as a connection, make sure that the unit is set for RGB if coming from a laptop or other computer system. If the projector is set to YPrPb, the picture will look purple or bluish as you describe. Change the setting to RGB and all should be well.
This is probably the polarizing filter. It will need to be replaced. It should not cost very much to fix. OR go to control panel, then go to display properties and try changing the theme to default.
If not successful replace the LCD panels.................sodeep
I took a look at the projector and the following is what I noted. Turn on PC and projector from...
(More)
I took a look at the projector and the following is what I noted. Turn on PC and projector from control panel. Standby/On button blinks green (means warming up) Let it go for several minutes and get no picture Shutdown PC and system from control panel Standby/On button blinks red and lamp light turns red After a minute or two Standby/On button solid red and lamp light stays red According to the manual I found online it sounds like the lamp needs to be changed?
Cannot get image from my laptop to projector. message reads "No input detected on RGB"...
(More)
Cannot get image from my laptop to projector. message reads "No input detected on RGB" Only power cord and RGB connections in place.
Well maintained Hitachi CP-X1250 ceiling mounted projector flickers after about 25 minutes of use...
(More)
Well maintained Hitachi CP-X1250 ceiling mounted projector flickers after about 25 minutes of use and continues to flicker at irregular intervals. Flickers with both VGA and Video inputs. I reseated the lamp and it still did it. I tried another projector (Eiki) to test the cables (60 feet long) and it did not flicker. Tried Kramer video amplifier and it still flickered.
a little red light comes on after the green one and then after 15 minutes the bulb and screen gets...
(More)
a little red light comes on after the green one and then after 15 minutes the bulb and screen gets turned off automatically.
