Question about Sony Playstation 3 (PS3) Console
I have the sony STR-DA5300ES amplifier and a sony a sony wega 70' tv with a dvi connection.For blu-ray I set the a video setting on the amplifier to use hdmi for video and an optical input for sound. I set the ps3 optical for dts 5.1 and dolby 5.1 , but I only get 2 channel sound when playing a blu-ray disc. I get great 5. (1?) sacd sound through an hdmi connection as long as the tv is off. I do notice that on some blu-rays rhe intro sourroun sound kicks in just for an intro
segment. Some of the blu-ray disks only give me the option of dolby or dts hd sound no regular 5.1 sound. When i play a game i get perfect 5.1 through the optical cable
  • 6 more comments
  • radman159 Jan 04, 2008
    I have a similar problem; regular DVD disk I can get surround sound but with Blue ray I get only stereo center right and left front speakers. I have changed from PCM to bit-rate and my receiver tell me that it is receiving but no sound comes out o surround speakers. I Have talked with tech support nobody knows answer. Receiver is Pioneer elite 74 vsx. help
  • bbenson255 Jan 08, 2008
    Same problem, only I have a Samsung DVD Home Theatre in a Box and I don't see an option for automatic for the digital audio input.
  • Anonymous Jan 10, 2008
    I am having the exact same problem, I have tried all the settings but still only get dolby 2.1
  • bspanza May 24, 2008
    So I get Surround sound when I play games, I get surround sound when I watch SD DVDs, but I don't get Surround sound when I watch Blue Ray, or when I listen to CD's. What the buck?
  • aclo Jul 10, 2008
    I got the same problem, No surround sound when playing blur-ray disk, only 2 channel sound.
  • Anonymous Jan 08, 2009
    oh yea get this. I haved a sony bravia with a sony inbox surround sound. I did everything to get my surround to work. Changed all sound settings(everything so don't ask) What do I do now.
  • Anonymous Feb 18, 2009
    I have the same problem
    have tick the boxes for 5.1 in audio setup
    but it will not transmit 5.1 surround sound the amplifier chooses stereo 2 channel
    downloading a demo game from the Internet you get surround sound
    but not from blu ray and PlayStation 3 game
  • austin83 May 11, 2010
    PS3 is The amazing device by sony but it has some common problems like sound problem, video problem etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
  • 36 Answers
Your amplifier should "downgrade" the signal to 5.1, even if the disc isn't using it. It is most likely a setting on your amp that may need adjusting for "types" of digital to accept on its input. If you can, set your optical input on your amp to "auto". This way it will automatically detect and switch for the proper incoming audio feed
Posted on Jan 03, 2008
Had same problem dvi connection is the cause.
STR-DA5300ES will only work with hdmi
Posted on May 27, 2008
I had the same prob. Changing the ps3 audio settings from linar to bit rate did the job 4 me. I have a samsung dvd surround sound in a box package
Posted on May 06, 2008
Buy a wii
Posted on Jan 29, 2008
Set all the settings to 5.1,dts, settings ,,REBOOT THE SYSTEM..and all blu rays will play in the dts or 5.1 setting
Posted on Jan 13, 2008
Can't get any sound when playing discs through a blu ray player connected via a hdmi cable and DVI adapter.
The DVI adapter stops the audio. Use the audio out ports on the bluray player to connect an audio pair cable to the tv.
Jan 08, 2014 | Hyundai Televison & Video
No Audio
cant use both hdmi and opti outs try sum setting in blue ray but u nee dto plug all blue ray dish directto samsung hdmi then 1 master digital out form tv to sterio digital i n ok tell samsung your output also
Jan 20, 2008 | Sony STR-DG510 Receiver
No sound through yamaha htr-5750 receiver and samsung blu-ray
That's because tha hdmi is desing to play sound to the reciver you may have to use out put sound from the unit.
Dec 06, 2013 | Sony STR-DG510 Receiver
Panasonic TV does not play through surround speakers
so it is a connections problem I think. Check if video and audio cables are properly connected. Use color codes as your guide. Also from menu check if all settings are ok. Good luck
Dec 01, 2013 | Panasonic DMP-BDT220 DMP-BDT220
No sound from Sony STR-DH500 when playing dvds with HDMI
no sound via hdmi cables, you must use optical or coaxial
Dec 10, 2009 | Sony STR-DH500 A/V Receiver
Surround sound for Blu Ray on older Sony receiver
Hello, it sounds to me like the receiver doesn't support the sound format being sent from the blu-ray player. This is because the blu-ray disc would have HD encoded sound such as DTS HD Master Audio or Dolby True HD. Most receivers have not been fitted with these sound formats untill quite recently. The reason for the menu sound playing correctly would be for the PCM (Pulse-code Modulation) which sends simple two channel digital sound supported by all digital receivers. It may be possible to use Dolby Pro Logic or similar formats to give a surround feel, but the only way to get true surround sound in this way would be decode the sound externally and input it through several phono cables into the multichannel input, however blu-ray sound comes in 7.1 so the receiver would need to be able to accept this to get the full effect. If it is possible, see if the blu-ray player will allow downsampling to a surround sound format that your receiver can accept such as Dolby Digital or DTS. Hope this helps.
Aug 21, 2009 | Audio Players & Recorders
Can't get 5.1 audio from bose surround system using PS3 blueray
Yes but first thing, the blu-ray disc you are playing must be 5.1 to get true 5.1. If it is an older movie/TV show, then it might be only 2 channel audio. If this is the case, then your Bose system needs to create simulated 5.1 surround sound, which is not true 5.1. However, if your blu-ray disc is a true 5.1, then your PS3 needs to be set to output 5.1. I am not familiar with the PS3 so I am not sure where to located that setting. Also, try other blu-ray discs.
Apr 25, 2009 | Sony Playstation 3 (PS3) Console
Blu ray connect to my sc-pt660
as far as hooking up your blu ray player to the sc-pt660, the only real way to utilize the surround sound (with true surround sound) is through the optical audio out. You need to connect your blu ray player through hdmi to your tv and then connect your blu ray player to your surround sound using the optical audio out/in. I, personally have the sc-pt660 hooked up through component cables so I don't waste an HDMI input on my TV. Except for cd's, there is no reason for you to use the actual dvd player part of the surround sound considering you have a blu ray player. In conclusion, hooking your blu ray player and the sc-pt660 up to get better video simply isnt possible (your blu ray player alone gives the best possible resolution, 1080p). As far as audio goes, run an optical audio cable from your blu ray player to your sc-pt660 to get true surround sound.
Mar 23, 2009 | Panasonic SC-PT660 Theater System
Distorted audio on my surround sound
If it does it with just the one disc it is probably the file that you burned. Does the file sound ok on the computer? Sometimes files that are downloaded have bad audio tracks and I have seen cases where the encoding software that you are using messes up the file when it is modifying the file.
Try another DVD or Blu-Ray disc and see if it still distorts. If it does then it may be a setting in the player or in the receiver.
Jan 01, 2009 | Sharp BDHP20U Blu-Ray Player
Sony STR-DA5300ES Audio Problem
I am posting this to try and get everyones audio problem for this receiver fixed. If you only connected the HDMI cable to the 510, you will not get sound. This receiver passes through HDMI only, no processing of audio. You must either connect a fiber optic or digital coax to the 510 for that respective HDMI input from the BD player, the DVD HDMI only accepts digital coax, and the Video2 HDMI only accepts fiber optic. If you BD player does not have digital coax out for audio, you must move the connection to Video2 HDMI and connect fiber optic to the Video2 fiber input. Sony butchered the whole purpose of HDMI with this receiver. Hope this heps you. By the way, it is hardware, no firmware update will correct this.
Jan 02, 2008 | Sony STR-DG510 Receiver
Sony Playstation 3 (PS3) Console Logo
5,411 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
