Whirlpool Cabrio  WTW6600SBT Top Load Washer
Problem for Whirlpool Cabrio WTW6600SBT Top Load Washer
Installed new RPS sensor and still get F50?
By ph92 on Oct 26, 2009
Installed new RPS sensor and still get F50? Is this worth fixing?
Comments:
Oct 26, 2009
- Thank you VERY much for the information. Ihave a model WTW6600sw2, SN CU2272324. Ihope the cntrol board is on whirlpool!
Best Solution
posted on Oct 26, 2009
Very Helpful)
Macmarkus
Rank: Guru
Rating: 91%, 69 votes
That depends, I've discovered through experience with replacing those "rps" , the fault actually was in the control. It was displaying an F50, but the rps was fine. Make sure your model & serial number don't fall under the recent rework issued by whirlpool,(give me the serial & model and I have a list I can check) if so the control will be replaced free of charge to you. Otherwise price out a new control. Sorry I can't provide part number or price right now, I'm on my iphone and not at home pc. Hope that helps. Good Luck
Comments:
Oct 26, 2009
- Hello,
It would appear your washer (according to the serial number) actually is built after the rework affected machines. The machines affected in the rework only include those starting with a serial number CS48 to CS52 and CT01 to CT49 units. Those are the first four digits in the serial number and only those are included for updates/reworks.
What this means of course is, unfortunately the control will not be covered by whirlpool (unless stated otherwise in your owners manual) and it usually retails for around $150-$175US. Part number to look for is a #1469076. Check your local parts depot or service centers. you can also find it on-line at many distributors, i.e "apwagner.com". "reliableparts.com" and "repairclinic.com" or "searspartsdirect.com" to name a few.
Hope that helps,
Good Luck :)
Was this helpful?
Yes
No
2 people thought this was helpful
Asker's Testimonial
" yes, very helpful! " - ph92
Popular Solutions for Whirlpool Cabrio WTW6600SBT
Questions and Unsolved Problems for Whirlpool Cabrio WTW6600SBT
Do you recommend Whirlpool Cabrio WTW6600SBT Top Load Washer?
Answer
Answer
cabrio washer wtw6600sw2 code sd. I did a cleaning cycle, then did 1 rinse/spin, and then did 1... (More)
Answer
washer lights up but will not start when start button is pushed in
Answer
when using cycle whiter whites, the cycle stops around 33 minutes, the dial to chose the type of... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Whirlpool Cabrio WTW6600SBT...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14935
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
