Question about Dryers
Dryer motor will not turn
I have a Whirlpool dryer that will turn on, but it makes a buzzing noise.I looked at the motor and it appears to be sticking,but will turn,occasionaly
    Problem Solver:
  • 27 Answers
You have teeth that are not connecting in the moter just like a starter moter on a car..Take moter out and find a motor rewind shop in the yellow pages they will either repair the motor or offer you a part exchange..hope this helps
Posted on Jan 01, 2008
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' ...
? 4:32
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
Whirlpool Dryer Motor 3395652
What is the complete model number of your unit?
Dec 03, 2012 | Kenmore 3976707 3395652 Whirlpool Dryer...
My dryer is not working and only making a buzzing noise when i press the start button
is the buzz more like a growl? if so, you probably have a bad motor. if it is truly a buzz, then try turing your timer to a different cycle. if the problem continues, replace the timer
Jan 22, 2011 | Whirlpool LER4634J Electric Dryer
My dryer will not work at all, it just makes a buzzing noise
If the sound is more of a hum than a buzz something has the motor in a bind or the motor has gone bad. Make sure you can turn the drum by hand and if you can not then check for something in the blower wheel.
May 28, 2010 | Whirlpool LER4634J Electric Dryer
Drum will not turn and there is no heat.
This dryer has a circuit board that controls virtually everything. If it makes a buzzing noise when you press the power button to turn on the control panel, it's probably not going to be an easy fix. When you hire a professional, you avoid buying expensive parts that you might not need, such as a control board. If it makes a loud buzzing noise when you press the start button, it's possible that it could be a motor or belt problem. But again, I'd recommend a service call for this one.
May 25, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool dryer makes a buzz noise when push
pull motor switch out(the one with wires go in motor) best use compressed air.... lint is stopping lever... this all happens after you turn breakers off...hi hi
Aug 27, 2009 | Whirlpool ET8CHEXSQ Dryer
Dryer is making loud thumping noise.
Take off the back panel of the dryer and look at the motor and belt turning the drum. There may be something caught on the drum and is pinned in place causing the noise. The motor could be loose on the platform and needs to be tightened. It is probably something physical and seen causing the noise.
Jan 04, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool condenser dryer not working. Power coming in to machine but that is about it.
does the machine make a buzzing noise? or heat up?
if it makes a buzzing noise and heats up it will more than likely be the motor surpressor, all this does is gives the motor a kick start to set it off tumbling with a wet load. theres a quick way you can check if it is this at fault, make sure the drum is empty and set timer as you would normally, open the door and spin the drum as hard as you can then shut the door quickly (whilst drum is still turning if you can), the dryer should now run normally until it stops again.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 05, 2008 | Whirlpool Dryers
Whirlpool noise
Ok can you take the front panel of the washer off easily?
If you can look for the motor pump assembly. Start the washer with no load, turn the water level down to the small and fill with water when it goes into agitation does it make the noise? if not turn timer to spin and see if motor makes the noise.
One other thought, maybe the smell is coming from the dryer?
Let me know. I wont be on line again until Friday Sorry
May 26, 2008 | Whirlpool LTE5243D Top Load Stacked...
Whirlpool lgr4634eqo makes a buzzing noise when trying to start
Try holding the door switch lever in and turning the drum hard by hand. It sounds like you have a start switch out in the motor.
May 20, 2008 | Whirlpool LGV4634JQ Gas Dryer
Dryers Logo
98 people viewed this question
Top Dryers Experts
