Ok this solution may be obvious but I'll say it in case you haven't tried everything; when you put the correct bobbin on the post,it has a slot which lines up with a metal spring on the winder post and makes an audible SNAP. Also you need to have the post with bobbin in place firmly snapped to the right for it to wind properly.Also check how you have the thread coming to the bobbin,follow the diagrams precisely.If it still doesn't work well, go buy a bobbin winder they're much easier anyway! Good Luck!
BRAND new Janome 1420qdc. New needle, doesn’t need oil. Will NOT wind a bobbin. Used almost an entire spook of thread doing this. At my wits end. HELP!
Under the top cover, on the right hand side where the bobbin winder is, there is a small switch which is activated when the bobbin is being wound. You will need to remove the cover and reposition the switch (it's located towards the front of the machine) to make it work properly. sewman7
