Question about Kenmore 62802 Electric Dryer
Motor runs, but no spin on Kenmore front load dryer
Its a kenmore 66812. The motor runs, or tries to, but will not spin.
  • Anonymous Jan 02, 2008
    motor runs but will not spin
  • timeka May 16, 2008
    the dryer is getting hot -- heat is coming out -- but the dryer will not spin! can someone offer some help?
    President:
  • 1,314 Answers
More than likely your belt has come off there is a panel in back remove it and look inside now the wheel that keeps the belt tight has a habit of coming off if some yahoo didn't put it on right find it and look for two slots in the floor of the drier it slips into put it in the slots and pull it down then put the belt on top of it should fix the problem
Posted on Jan 01, 2008
11076812693 drum won't turn.
Kenmore Dryer Model 110.76812693 (11076812693) Drum ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Drum-T...
Kenmore Dryer Model 110.76812693 (11076812693) Drum & Tub Parts in stock. One million parts for 125 brands. Guaranteed same-day shipping. Call 7 days ...
Kenmore Dryer Model 110.76812693 (11076812693) Motor ...
www.repairclinic.com/.../Model-11076812693-Kenmore-Dryer-Motor-...
Includes pulley for dryer drum drive belt. Other shaft has reverse threads for blower wheel. Common symptoms of a bad drive motor are: -Dryer stops turning ...
Kenmore, Whirlpool Dryer Repair - Heats properly, drum will ...
? 6:29
https://www.youtube.com/watch?v=bOShDc4kLfk
Jul 10, 2013 - Uploaded by ApplianceVideo.com
Service a Kenmore Dryer with some of the following issues: Heats but ... Kenmore, Whirlpool Dryer Repair - Heats properly,drum will not turn - 11068202794 ..... Whirlpool Kenmore Maytag Amana Dryer Won't Start - Easy Fix ...
How To Fix Dryer That Won't Tumble ' Dryer Repair
www.partselect.com/Repair/Dryer/Will-Not-Tumble/
Feb 08, 2016 | Kenmore Dryers
I have a Kenmore Electric Dryer Model 66812. The motor runs, but the heat doesn't come on ... so it's not drying. What's wrong? Is it worth fixing? Estimate to fix?
ELECTRIC Dryer no heat or little heat:
Check your venting and lint basket. Check blower for lint build up and blower wheel obstruction., test by trying to turn the wheel manually by hand (should be easy) May have to remove cabinet or front/back plate to get to it)
Next check the heating element itself with a meter for continuity OHMS CLOSED CIRCUIT. If not its defective.
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage. 220 because if u only get half or 110 volts you will be able to run the machine which uses only 110 to run motor but not the heater which uses a full 220,
Check the thermal cut off, the cycling and the hi limit thermostats.
For continuity or OHMS. If no ohms or resistance they need replacement.
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
May 12, 2014 | Kenmore 62802 Electric Dryer
I typed in 66812 not the number that is showing - I need to know what receptacle to use with the Kenmore 66812 electric dryer. Thanks for any help you can give me.
on the front of dryer open the door there should be a tag or on the rear where the cord goes into the dryer there should be a tag to tell you what the voltage is
should be a 250 volt plug and outlet to match
nema # plug-S42 AND THE OUTLET # 6-30 OR 6-50
Oct 17, 2009 | Kenmore 62602 Electric Dryer
Have a kenmore all in one washer dryer that will
firstly check the motor bushes as this can cause this problem.
Jul 15, 2009 | Electrolux Kenmore 3.5 cu. ft. I.E.C....
Won't spin anymore. Comes on, but barrell won't spin. dead motor?
Do you hear the motor running? It may just be a broken belt. If it is in fact the motor it can be replaced.
May 28, 2009 | Kenmore Dryers
I can hear it running--but it doesn't spin
your belt is broken the heat should still work.
Aug 29, 2008 | Kenmore 62802 Electric Dryer
Spins very slow on rinse/drain and spin
Your filter &/or pump could be blocked. Remove bottom panel three screws, unscrew filter cap (have lots of towels cause it will drain), remove filter & clean out. Refit. If you have manual refer to it. Pl rate me if helped.
Jan 20, 2008 | Kenmore 46462 Front Load Washer
Dryer wont spin
Doe the motor running ? if run w/out spinning the beltis the problem / bring sample to appliances center.
Aug 25, 2007 | Kenmore 45081 Front Load Washer / Dryer
Kenmore 62802 Electric Dryer Logo
128 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
