Question about Pioneer PRO-200 60" Rear Projection Television
Pioneer projection sd-p403
Sound from satellite comes on randomly and with no picture.
The screen looks like a bad 3D movie without the glasses. Anyone know how to fix this?
Posted on Feb 05, 2008
SOURCE:
No picture on my pioneer TV model SD-582hd5
The problem is on lamp try to replace it to get back the picture..
Feb 23, 2012 | Pioneer SD-P55A3-K 55" Rear Projection...
Tv wont turn on
bad connection. if you have some electronics experience, unplug the tv and carefully open the back , remove the main bord and check for soldering using the magnifier. if you check very good , you will see a sort of small line around the soldering . that small line are bad connection , re-solder them .
Sep 15, 2009 | Pioneer PRO-200 60" Rear Projection...
Dark screen on a pioneer SD-P403
By the desciption of your symtom, I think that you may have lost the blue CRT. You may want to call a local repair servicer to have the set diagnosed. It could be as simple as the video driver on the CRT board, or it could the the CRT itself.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. (Two Thumbs Up) If you cant rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jun 21, 2009 | Pioneer PRO-200 60" Rear Projection...
Pioneer tv
This is a common problem with pioneers. try resoldering the vertical output Ic that should remedy the problem. if not the vertical IC may be faulty
May 27, 2008 | Pioneer SD-P55A3-K 55" Rear Projection...
No picture
deflection problem check the regulators and Horizontal output transistors. let me know if you need anymore Info.
Feb 04, 2008 | Pioneer SD-643HD5 64" Rear Projection...
SD-P403 PROJECTION MONITER RECEIVER
Most likely the switch is bad. But it could also be the relay that the switch controls... if your mechanically inclined, get back with me.
Jeff
Nov 28, 2007 | Pioneer PRO-200 60" Rear Projection...
Pioneer SD 5575 - Needs to wam up
best thing i can suggest is buying a can of freeze from radio shack and spraying each ic/transistor till the problem appears again.
Nov 11, 2007 | Pioneer SD-533HD5 53" Rear Projection HDTV
Pioneer SD-P40
Check your hori out put transistor if shorted replace NTE2973, this should be output number.if you need any more help let me know!
Oct 12, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer PRO-200 60" Rear Projection Television Logo
81 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
