Question about GE GSL25JFPBS Side by Side Refrigerator
No water at door
Our GE fridge is getting no water at the door.
We were away for 10 days so it wasnt used during that time. While the thermostat was turned down cold (55F) during vacation, it didnt freeze in here.
I click the lever, I hear the solenoid click, but no water. I reseated the filter bowl, and had the lever pushed in while the switch was set to dispense water with the filter bowl off, and no water was at the inlet to the filter bowl.
  • dougsnow Jan 02, 2008
    To clarify, the thermostat set to 55F was the house thermometer.
    Would that still cause a line to freeze?
  • 9 Answers
I have a 3 year old GE GSL25 refrigerator with the water/ice dispenser on the freezer door. Even when setting the freezer at 2 and turning the fridge's lower drawer to the warmer "cheese" setting, the water dispenser line would freeze every few weeks. If you have this problem, first verify that the water filter (back of the fridge) is not clogged and that water flows from the water line at the bottom left corner of the freezer door (disconnect and press water delivery dispenser-see owners manual).
I used the hair dryer recommendation to unfreeze the line by heating the flat area of the freezer door directly behind the water dispenser area (~10 min did it). The trick to keep it from freezing up again involved buying a cheap foam sleeping bag mattress (~1/3 inch or 1 cm thick) made of a polyurethane foam (pretty dense). I cut it to match the flat area of the freezer door behind the water dispenser and taped it to the door with packing tape. For the past 3 weeks (even with freezer at #4 setting), my water is flowing freely. Personally, I think this solves a product defect with insufficient insulation in the freezer door near the dispenser water line.
Posted on Jan 24, 2008
    New Friend:
  • 8 Answers
A Water Tube Heater WR49X10173 will fix the frozen water line issue. It fixed mine. You can call GE and tell them your problem, and if you're kind and persistent, they will send you a free heater kit. Worked for me. Otherwise check eBay.
Rumor has it this problem is caused by water vapor getting absorbed by the foam insulation inside of the freezer door, and then the insulation doesn't insulate as well, and the cold from the freezer reaches the water line.
However...about a year later, your problem will be back.
As time passes, it will absorb more moisture, and the heater kit will not work anymore. I've seen several posts where the problem came back, with no solution.
So here's your permanent fix-ya:
Buy a second heater kit, and remove the foil sticky wrapper from the wire. The center portion between the black heat-shrink portions is the actual heater; the other end wires are normal wire.
Wrap the center portion tightly around right where the water tube comes out of the door, just below the ice dispenser flapper. Put some large heat shrink (not electrical tape - it won't hold) over the two existing heat shrink portions to hold the loop tight against the dispenser tube. I then put some aluminum foil tape, used for sealing duct work, over the loop and onto a portion of the dispenser tube, to hold it in place.
Connect it the same way electrically, so you now have two heaters in the circuit.
Then reassemble. You will need to take a Dremel tool to widen the hang-down actuator that your glass pushes on to dispense, around the dispenser tube. I needed about a 3/4" wide slot. This is because it will hit the coil of heater wire. Also be sure wires are out of the way behind this actuator as you reassemble everything, or the switch won't work reliably.
Mine had been frozen solid for a year, and it started working in the 2-3 minutes after I connected the front panel, which powers the heaters. Amazing!
The theory I used to come up with this solution is this: put gently heated air up the dispenser pipe, and it will steam the ice away. Voila!
Enjoy your water dispenser.
And yes, it's a very bad design, putting a water tube through a freezer door. What were they thinking?
Posted on Jun 15, 2015
G.E. had a problem with inadequite isulation in the dors of their GSH25KGMC** models. Maybe yours suffer the same illness. The G.E. repairman said that in high humidity areas, it wasn't uncommon for ice to form inside the freezer door between the inside and outside walls. Hence, "frozen line," no water from the dispenser! Thankfully, our extended warranty got us two new (and improved?) doors. I must say the problem has gone away since that fix. Had we been responsible for the charges, it would have cost about 900 bucks. Phooey, I'd buy a new fridge before I would pay that for doors. Good luck...
Posted on Mar 06, 2008
Set the freezer to the highest setting (8 degrees). Then wait a few days. The water line in the door is frozen.
Posted on Jan 01, 2008
Drain clogged on MCBR415S
Unless that fridge has an automatic defrosting cycle, NO water should be collecting at the drain area under normal circumstances. The only time that drain is needed is during defrosting (manual or auto).
Does the unit ever turn the cool cycle off or is the fridge always running (does the fridge ever stop humming)? If the fridge is always running, ice will build up in the fridge and it is either because the thermostat is broken or the door is not sealing properly allowing the cold air to escape. This can be due to something inside the fridge is preventing the door from closing properly, the door itself being not properly aligned with the fridge compartment, a broken door seal or a bend door or a bend fridge frame.
Ice can build up fast when a fridge is installed in an area with high humidity (like in Florida) and the door is opened frequently (like every 5 minutes to get a beer out, like during a house party).
If the fridge door seems to seal properly and the fridge seems to keep things cool, it might be enough to defrost the fridge to get it back in proper operating condition.
When loading the fridge, allow enough space between items, to permit the air to circulate.
Good luck :)
Jan 06, 2014 | Magic Chef Refrigerators
My ge profile arctica is about 9 years old. It is freezing food in the refrigerator, temp control is set at a 4 and the thermometer inside reads anywhere from 28 -40 in various areas of the fridge. Milk...
first run the diagnostics on the unit from the tech sheet inside the unit,then if thermistors are bad replace these there are 2 one on the left and one on the right wall in both fridge and freezer,if good per diagnostics then replace the electronic damper door located between the fridge and freezer compartments in the upper left hand corner of the fridge behind the plastic grille as these doors break and jamb open or shut and the temps can no longer be regulated during the diagnostics tests you can hear this door operate if its operating correctly,lastly,if these fail to solve your problem,replace the main control board in the back behind a panel
Aug 22, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator/freezer stopped cooling during a heat wave
Good day,
Turning the thermostat to a warmer setting should not have caused the machine to quit cooling. Actually, the engineers give you far less leeway than you might think.
The controls are more in a class of fine tuning, otherwise people would be getting themselves into trouble. The manufacturers simply design the warm and cold parameters in a fairly narrow range.
The best setting is normal. When away, the machine will run far less simply because of no door openings. Opening a door lets in large amounts of air every time it's done, which is where your cost to run it exists.
Two things. One, if the temp in the kitchen exceeded 90 degrees for any length of time, you are operating it beyond it's design range, however two, it sounds as if the thermostat hung up, causing your issue. You may want to have it replaced, but it would be useless to call anyone when it's performing normally.
There is no test on thermostats other than by observing their action when the machine is not operating properly.
Jul 08, 2010 | Kenmore 64802 Top Freezer Refrigerator
Fridge compressor keeps working all the time
Check the thermostat bulb in the freezer section. If it is encased in ice defrost for 24hrs. If this does not correct it fit new thermostat, but take care not to damage bulb or tubing it is gas filled.
Apr 16, 2010 | GE Profile Arctica Stainless Steel Top...
Hello, my hotpoint FF187E fridge freezer keeps tripping my electric off, sometimes it will stay on for a couple of days other times it does this straight away, any idears would be appreciated, thanks...
you may have a burned wiring which when wet trips off you electricity. the location may be in front of your unit between the doors if you have a two door fridge. if you have a singole door unit it may be located on lower area of the fridge body which where the water flow down when you have excess water dripping infront of your fridge. those two location are most likely because the wiring installations from thermostat, heater, and ligth are there. ofcourse you have to check first the compressor and it's auxillaries
Jan 13, 2010 | Freezers
2002 GE Artica Fridge stoppped cooling and freezing.
Hi monica ,
the heating element in your freezer might be bad or the thermostat. that is way your freezer is not melting the ice inside and the noise that you hear it's the fan that prob' tuch ice or also is getting bad.
let me know if you need more help...
Jan 08, 2010 | Refrigerators
Ge sxs model GSH25KGRB BB. We have water and ice in the door and when using the water in the door, the water doesnt stop running out even after you pull glass away and we have started to see water frozen...
your water valve might be bad it locate behinde the fridg on the bottom you need to pool out the pip from it to see if it still leak..
contact me at www.911servicetoday.com
Dec 30, 2009 | GE GSH25KGR Side by Side Refrigerator
Water build up on inside of fridge door of ge french door fridge
humid air in the house. any time you open the fridge, house air is sucked in. when you close it, the fridge cools the air and moisture from the warm air condenses on any cold surface. also check to see if there is a gap in the seal.
Aug 26, 2009 | GE Profile Bottom-Freezer Refrigerator...
Creaking Sound when Opening Door of GE Profile PTS22LHSCC Refrigerator
My GE creaks too, and it started after we pulled it out for cleaning. It is normally the door hinges. Spray them with Jigaloo which is a dry silicone lubricant.
Try this. Go to your local tire repair place. Ask them for an old inner tube. Cut a double thickness square with scissors and put it under the 4 corners under where the wheels are. It should help them to become self leveling and also sound insulating..
Mar 23, 2017 | GE Profile PTS22LHSCC 33" 21.7 Cu. Ft....
GE GSL25JFPBS Side by Side Refrigerator Logo
595 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
richie46
