Are all the bluetooth devices that you are looking for active or switch on and set to discoverable that is the only way they will be seen by a bluetooth device searching for it.
go to www.brvp.com you can download if from there
Install the hardware for Bluetooth. If you do not have the
latest drivers, download and install them.
Insert the software CD that was provided with your mobile
phone and download the software. If you do not have this software, you can
download it from the manufacturer's website.
Turn on Bluetooth on your cell phone. Ensure that it is
visible to your accompanying devices. Also make sure that Bluetooth is enabled
in both your system and mobile phone.
Click on your "Start" button and then your
"Control Panel." Double-click on "Bluetooth Devices."
Click
on "Add Device." Once it is done searching, pick your mobile phone
from the list.
Choose any of the options on the list if you are prompted to
enter a passcode. You may also proceed without using a passcode.
Enter your selected passcode if you chose one, ensuring that
it is the same one on your phone. Your mobile phone and computer can now
communicate with each other.
Run the software that came with your mobile phone. You will
get options to "Backup" or "Sync" your phone depending on
the software and the make and model of mobile phone.
hope it helps, if so do rate the solution
