Question about RCA P52926 52" Rear Projection Television
I have a shorting sound than no picture.
I have inspected all the boards and there are no signs of arcing on the tops or bottoms of any of the boards. i checked all the connectors for tightness. i removed the box from the set. when i turn the tv on it may work for 2 minutes or sometimes longer but never more than 5 minutes or so. I have noticed that if i tap on the plastic holder on the left it shorts out quickly. i do have sound at all times. Thank you in advance. Randy
  • 4,402 Answers
I would check the flyback transformer/splitter im sure it coming from there.
Posted on Jan 09, 2008
Why no sound or picture?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Jun 07, 2015 | RCA Televison & Video
Magnavox 51MP6200D/37
The conversion board needs replaced.
Dec 11, 2007 | Philips Magnavox 27MS343S 27" TV
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
Have a HDTV, model number HD52W67 , has no picture. My wife informed me that she saw a spark come from the back bottom. Spoke with someone who told me that this TV does not have a lamp but a tube. Need...
Most of the time when I have seen this it was either caused by a high voltage component leg arcing where the solder joint has gone cold, or the high voltage transformer is arcing. Most all the parts for this set are no longer available including the high voltage transformer and the board it is on. If the set is working, I would see if the power/ high-voltage board has a bad solder connection that is arcing. If it goes too far, the board will be burnt beyond repair. When you take the back off the set, it will be the board on the left. It is important to remove all the screws holding the board in place and flexing the lock tabs. It is a little tricky to get out. Once it is out, inspect the bottom of the board for any arcs marks. If you see one, make sure you remove all the carbon trail and re solder the component leg. Reinstall and before powering it up be sure all the plug connectors are in their proper place.
I hope this helps,
Dec 10, 2010 | RCA HD52W56 52" Rear Projection HDTV
My TV was snapping or arcing then no picture at
Sorry to hear this. What has happened is that CRT coolant has leaked from one or more CRT's down onto the Main bd and or the Power Supply bds and shorted them. You must replaced ALL three CRT's and the shorted Main bd and or the Power Supply boards. Then a Full Convergence Alignment must be done by a very good and experienced tech. Not cheap.
Apr 04, 2010 | Samsung PCL545R 54" Rear Projection...
Philips 60pp9200d/37 no video or sound. Power light flashes error 61. There is a spark gap component on the LSB board which arcs when the set is first plugged in, before the error is flashed. Picture...
I do recommend checking the power coming out of the power supply to make sure it is not to high. It is common for these units to have faulty internal capacitors in the power supply. It may be shorting out other components. You can buy a capacitor tester or use an ohmmeter.
Oct 08, 2009 | Televison & Video
Picture goes black mins after watching
Bad flyback transformer. It has a short in the winding making the Horizontal output transistor heat up so when its too hot the set goes into protection.
Aug 25, 2009 | RCA D52W23 52" HDTV CRT TV
Picture on and off
The problem is definitely NOT the tube. Sounds like adry solder joint on the pcb. Only way to find it is to inspect the pcb and resolder. Joints that usually go are where the heavy transformer are seated. Get it sorted else it may arc as it gets worse and burn or..the arcing may blow a component on the board.
Aug 04, 2009 | JVC Televison & Video
Smoke came out of the steering column near the turn signal lever while driving... top of the steering column was very warm to the touch. Smoke stopped shortly after I shut off the car...Dealer claims they...
sounds like you got some wires shotring, did they check wiring? remove column panels and inspect wire contacts, plugs and harness for signs of scorchining or arcing or burnt insulation, repair as nessasery
Jul 09, 2009 | 2006 Kia Rio
D52W19 No pix, sound good - now green light blinks, no come on
First of all you need to find out which CRT leaked and replace it before any other repairs are done. The clear liquid is conductive and has done damage to the CRT board or boards.
Jun 15, 2008 | RCA D52W19 52" Rear Projection Television
RCA P52926 52" Rear Projection Television Logo
18 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
