Question about HP Photosmart C3180 All-In-One InkJet Printer
Hp Photosmart C3180-start-up
Each time i turn the power on the printer it prints an alingment page--wasting paper and ink!!!
Re: Hp Photosmart C3180-start-up
Okay, just chatted online with an HP tech, and she helped me solve the problem!
She said: the printer prints an alignment page everytime you turn on due to incomplete initialization process.
Turn off the printer and Turn on.
Please unplug the usbcable.
  1. Lift the scanner lid of the product.
  2. Place the top of alignment page face down in the left front corner of the glass.
  3. Place the alignment page face down
  4. Close the scanner lid of the printer.
  5. Press the Scan button.
  6. The On/Resume light will blink during the alignment process.
  7. After the On/Resume light stops blinking, alignment is complete.
  8. Turn off printer and Turn on.
It shouldn't print the alignment page any more! :)
Hope this helps!
Posted on Jan 01, 2008
  • 619 Answers
The printer problem having been recorded printer memory , during the printer problem occur you may unplug USB cable in order to reset the memory of the printer.
0 characters
3 Points
Every time we turn on the printer, it prints a test sheet. how can we stop this? it's a waste of paper and ink.
Not knowing what printer or O/S you have, try this:
Open START, Control Panel, Printers.
Select the printer that needs tweaking.
It should open a pop-up screen for that printer.
Click PRINTER from top left and select "Printing Preferences" or "Properties" from the list.
Somewhere in there each manufacturer has availability to turn on or off many features of your printer, including cover page and start-up test.
This is also where you can change your default to print in grey-scale or low-mode which is also a great ink saver. MOST of what we print doesn't need to be in color or anything beyond ReadAble! When you want to print photos or special documents, it's simple to click back to color mode.
HOPE this helps ... Meezer
May 03, 2010 | HP Photosmart C3180 All-In-One InkJet...
Printer starts up doing a printer test page
Maybe there is a some thing in your priter driver page when you go to print go to where it says (print setup) look in there but most printers I know do the same thing I not turn my printer off thats the best way just leave it on standby or you will use lots of ink ever time it stats up and papper
Jan 23, 2010 | HP Photosmart C3180 All-In-One InkJet...
Mac OS 10.5.8 HP Photosmart C3180 does not print
Exactly what I'm experiencing, it goes though all the motions, but no ink is on the paper. I just installed 10.5.8 last night on my Mac Pro. The drivers are up to date, but no ink hits the paper.
Sep 22, 2009 | HP Photosmart C3180 All-In-One InkJet...
Alignment page prints every time I turn on the printer. This just started when I installed a new black cartridge. It's totally wasting my ink!
plz give print test page and after printing the test page you have to put the print paper in the scanner and push the scan button
Jun 25, 2009 | HP Photosmart C3180 All-In-One InkJet...
HP Photosmart C3100 series
I just got off the HP help line.  After changing my black ink cartridge a test page was printing each time I turned the machine on.  This is very costly, in both time and ink as the cartridges themselves for this machine hold very little ink.  I tried to learn from HP tech how to turn off the test-print while keeping my color cartridge empty.  It turns out that you cant do it.  HP requires you to keep buying and using cartridges whether you need them or not.If you buy the color ink it will use it up in its testings.  And if you dont buy the color cartridge it will use up your black ink by printing the test each time you turn on the printer.  The printer was inexpensive sure, but I'm paying for it in wasted ink.
Dec 26, 2007 | HP Photosmart C3180 All-In-One InkJet...
Test Page Prints Everytime Printer Cuts On
this is happen when you install an new catridge or refill one printer is automatically adjust the catridge by alingment so you do one thing when you switch on printer and it will print something just read the instrction and follow them bcoz you need to setup the alingment thing . when the print is come out just place it in to the scanner and just press the scan button the printer will store the setting and next time not print the extra page bcoz the setup is completed.
Nov 02, 2007 | HP Photosmart C3180 All-In-One InkJet...
Deteriorating Print Quality
This is Maltesecross. Turns out that the faintness of my printed pages was in fact due to a low ink cartridge, even though some pages printed out fine and others half-good. Eventually, all pages turned faint, and upon re-installing the driver, I got a low-ink warning (the first one ever). Putting in a new ink cartridge solved the problem for me.
Oct 21, 2007 | HP Photosmart C3180 All-In-One InkJet...
HP Photosmart all in one C3180
My suggestion: Don't buy HP. I have the same region coding problem. All I want to do is buy HP ink, put it in my HP printer and print stuff. Too hard. I've wasted 30 pounds on ink and another 30 pounds on "support" phone calls to HP. Hopeless. I will never buy HP again. Waste of time and money.
Aug 24, 2007 | HP PSC 1610 All-In-One InkJet Printer
HP Photosmart C3180 All-In-One InkJet Printer Logo
1,281 people viewed this question
Top HP Printers & Copiers Experts
Brian Sullivan
Brian Sullivan
Are you a HP Printer and Copier Expert? Answer questions, earn points and help others
