I own a 2006 Toyota Highlander Limited Hybrid and want to change the navigation DVD How do I find it? how do I change it? Are there any precautions before I start?
DVD unit is under the passenger seat. Just buy the new maps DVD from the dealer, eject the old disk (button on the left, covered with slider) and put the new disk in. It takes 10 minutes.
Question edited for clarity add maker.
Question moved to model category.
Your question as written makes no sense. You made an earlier post 10 minutes before asking "How do check fuel pump is working".
Although badly written, (How do you check that the fuel pump is working?), I can answer that.
In the engine bay on the fuel rail there is a port that looks like a tyre stem called a Schrader Valve. You connect a fuel pressure gauge to it and test the fuel pressure when turning the engine over to start it. The pressure should be 44-50 PSI.
Question edited for clarity and add a few spaces and capital letters. :>D
That code is the opposite, it isn't REACHNG temperature it should. However, I had that code and changing the thermostat, got rid of the code.
Error code P0128 indicates that your engine coolant temperature is below the thermostat regulating temperature. This means that your Engine Control Module (ECM) or Powertrain Control Module (PCM) has recognized that your engine is running cooler than it's supposed to.
i think its not hardware problem can u check any alarm are symbol which is showing on ur display if its try to fix it .due to it was interlock until u not clear it ur machine will never move.
take the inner pannel off and there will be two clips,screws ors bolts just simply remove theese and sisonect wiring it should just push inward and come right out.
The below site can provide a 'vehicle reference manual.' not the actual original owners manual. It is free, hope it has the info you need http://qrg.toyotapartsandservice.com/
