Question about Gateway Media Center 610XL (610XLMDIA) PC Desktop
Gateway Power Supply
I have a gateway media center 610xl & need to install a new power supply, I purchased a 185watt replacement delta DPS-185JB-1 A. I'm not sure how to install it & it seems this is the original part so won't the same problem happen again (total burnout due to using too much power)? Is there a newly revised part out there to fix this problem, I've found external units but that defeats the purpose of the design of the system. Please help, gateway sold me a 3 year warranty then reneged although they never gave my money back they also sold me a DC-50 camera that has never worked & would not fix it. I am technical enough I think I can do this with some help.
Thank you in advance for any help
Kerrie Rumbut
krumbut@sprintpcs.com
  • JustAskKat Jan 01, 2008
    What would cause the computer to go out except the USB light is on. Would the power supply do it?
    Problem Solver:
  • 9 Answers
It's not likley the power usage that did in the power supply unless you split the feeds numerous times. The switch should be straightforward, unplug all the feeds paying attention to what you unplug and only unplug what comes from the power supply. It should be a simple matter then to unscrew the supply from the case, remove the old and reverse the operation.
Posted on Jan 01, 2008
  • bcroydon
    bcroydon Jan 01, 2008
    Since you have the supply switch it out and see but if the power supply was a total loss nothing would be powered but it is possible if it's pushing some power. When unplugging from the motherboard there may be a connection lock (plastic tab) that you may need to squeeze to release.
Remove the sub-woffer (speaker) from the rear of the system, then remove the thin aluminum cover, there you have it staring you right in the face.
Posted on Aug 15, 2008
It doesnt boot up at all , good power,but nothing past the power cord.
Most likely the power supply inside the unit is bad. Try replacing the internal powersupply.If possibe.
Jun 09, 2010 | Gateway Media Center 610XL (610XLMDIA) PC...
Need basic instrux on how to exchange hard drives from one gateway media center 610 to another
take off the cover and unplug the hd from one and put it in the next one, it is only 2 plugs and you can not plug them in wrong it will be a 4 pin power cord coming from the power supply and a data cable, depending on how old your computer is it will be a small cable with a black connector or a larger one that looks like a ribbion either one you can not plug them in the wrong way. The power plug you can put anyone of the extra ones into it! If it fits it will work, depending on if the hardware in the two computers, you most likley will have to repair or reinstall windows!
Nov 14, 2009 | Gateway Media Center 610XL PC Desktop
Power cuts off or does not start
Check the power cord if it is connected correctly, if does then probably there is problem with the power supply or in the motherboard. Try also replacing the power cords of the power supply.
Oct 21, 2009 | Gateway Media Center 610XL (610XLMDIA) PC...
I have a gateway media center 610xl that has no power.
if you know on how to replace the power supply then do it, if not proceed to bring the computer. or if you have friends can do this, then much better.
Mar 15, 2009 | Gateway Media Center 610XL (610XLMDIA) PC...
How do I change the video card in my 610XL PC?
After the side of the case is opened and the computer unpluged and the video to the monitor unplugged, if it has a card already installed , remove the screw holding the card down then pull the old card straight up out of the card slot. Align the new card that you purchased , pushing it straight down into the slot. Install the hold down screw. Reinstall the side . Install the software after hooking  the computer and monitor up.   If you don;t jknow which type of card ,down load a manual and maybe even further instructions from the weblink I provided.
Below it the Gateway support center for your model. All you have to do is to put in your 22 digit serial number.
http://support.gateway.com/support/drivers/dlcenter.asp
Feb 16, 2009 | Gateway Media Center 610XL (610XLMDIA) PC...
How do I install a power supply in a gateway 610xl computer?
REMOVE THE CASE AND UNPLUG ALL.THERE SHOULD BE 4 SCREWS HOLDING IT IN PLACE REMOVE THEM.REINSTALL NEW IN REVERSE.RICHARDM69
Nov 26, 2008 | Gateway Media Center 610XL PC Desktop
Gateway 610XL Disassembly
take cover off top of base.- pry off
remove two screws that hold speaker unit, it will tilt out, disconnect cables and remove speaker.
two screws on back of base and then take off back cover.remove sheild cover.
disconnect all cables. 4 screws hold power supply in.
rca connector board has little black button holding it on. pry up and then remove board to access connecters behind.
pull all cables out towards you.
remove 6 screws that hold base to back of screen, pull up tape under where cables go thru hole.
remove base from screen.
take out screws on back of screen. carefully pry all around case to seperate.
remove back, and then sheild. there are a few screws that hold it on.
If your screen was black, then the two inverter boards could be the problem. there is one in the upper left corner and one in the lower left corner. you can by them on internet. match the partnumber, there are 2 diffent ones.
Nov 05, 2008 | Gateway Media Center 610XL PC Desktop
Power supply installation in gateway 610xl
to replace a standard ATX powersupply;
remove left hand side cover (ensure power is disconnected first);
disconnect the 20.24 pin primary power plug (big wide white one plugs directly onto the mainboard, also disconnect the 4 pin AUX power plug, looks just like the other one but is a smaller square shaped plug (older P3 boards will not have this)
disconnect all 4 pin power plugs from hard drives/cd drives and aftermarket fans (if any are installed), disconnect SATA power plugs from any SATA devices installed (flat black plug, 4 wires)
disconnect floppy drive power plug (if app) small while 4 pin power plug, once all of these are disconnected, looking at the rear of the computer there will be 4 screws holding the power supply in place, one screw will be more to the centre slightly to ensure you do not put it in upside down, once you remove those screws the power supply will slide right out.. simply re-do these steps in revers for instaling the new power supply
David
Feb 28, 2008 | Gateway Media Center 610XL PC Desktop
Power Supply/Video on/off problem
hi, seems to be a problem design, you can check the users review on: http://reviews.digitaltrends.com/review1430.html options 1,5 even 6 is ok. sorry.
Aug 26, 2007 | Gateway /ton 160W Power Supply (6500582)...
Gateway Media Center PC is on, but there is no picture.
I have been fixing one for a customer. At first I thought that it was the typical burned out powersupply. Delta Electronics has created a replacement. The old REV 00 is 185 watts peak. The new REV01 is 185 nominal. Was the shaggy067 did not take the time to look up is that the 610 is an "All in one" modular monitor/case.
This customers is the first one that I have replace the power supply and it still does not work. I believe the flourescent backer of the LCD is shot. I will not know for sure until I find another one. The S-video works fine, so I am testing it using my projector. Everything works except the lcd panel.
Oct 21, 2006 | Gateway Media Center 610XL PC Desktop
Gateway Media Center 610XL (610XLMDIA) PC Desktop Logo
182 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
