Question about Maytag Neptune MAH5500B Front Load Washer
Grinding noise My maytag neptune is approx. 6 yrs. old and just recently started making a grinding noise in the spin cycle. It sounds like a bad bearing of sorts. Is there a replaceable bearing available for the drum or drive mechanism that is causing this?
  • 1 more comment
  • josh1111 Jan 03, 2008
    spin cycle is really loud on my maytag neptune mah 5500 any help?
  • pablo123 Feb 06, 2008
    After watching the Tonytool video I managed to replace both bearings and seal on my Maytag MAH4000 using a common triangular puller along with a variety of bushings and washers, some of which I adapted from old sockets ground down to size. However, the inner bearing (larger one) broke in pieces and had to be finally cut out with a high speed cutter. Took me the better part of a day but total cost was about $80 ( $45-sealkit from Maytag & $35 for both bearings bought locally). I just hope I can get another 7 years or more until the next ones wear out.
  • mapleleaf666 Feb 06, 2008
    My Maytag washer also is about 6 years old and started making a grinding noise during the spin cycle. Please let me know if this is an easy fix. I am mechanically inclined and do have allot of tools at my dispossal. Can you buy these bearing seperately and is there a step by step repair manual that I can use....Please advise
    Thanks
    Frank
    Scholar:
  • 79 Answers
The Neptune bearings are an interesting breed... Maytag wants you to replace the whole outer tub which includes the bearings installed for $180 or so. You can replace the bearings yourself. See www.tonytool.com to see how it is done. The tool costs $379 or so... but it is designed for the service tech. not the d.i.y.er. But watching the video can give you an idea of how to do it yourself. The bearings were available on www.neptunewaxmotor.com for about $35.00. You will also need the Maytag seal kit 12002022 to complete the job whether you decide to replace bearings or the outer tub.
Posted on Jan 05, 2008
  • 398 Answers
I found it was better to buy a new washer because this bearing is a baaaad design. i tore it all apart only to find the bearing shot and grease all over. the bearing was so curroded in the drum it woould not come out no matter what. forget it . if you have this problem buy a new one or deal with the noise. it would have worked fine for a few more years it just sounded like a airplane was taking off in the basement.
Posted on Feb 19, 2009
I just took my Neptune MAH5500BWW apart and found that the bearings are shot. My local Maytag service provider quoted me $425.00 for the whole outer tub! I would have bene happy with $180.
Posted on Feb 07, 2008
Loud noises during spin cycles
Hello, If the noise is a squealing or grinding sound, you are likely looking at a bad seal and bearing.
If the noise is a knocking sound, it's more likely a suspension or out of balance condition.
Thanks
Jun 12, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune
There is 2 possible problems. 1. Pump will make noise as soon as the drain and spin starts. 2. Rear bearing this noise usually starts later in cycle as the drum gets up to final speed. The rear bearing of coarse is the most expensive of the two as it is part of the outer tub.
Mar 04, 2010 | Maytag Neptune MAH5500B Front Load Washer
Making loud noise in the spin cycle and now does not spin at all
Sounds like the tub bearing is gone. Get it checked out though. It could be the pump bearing, a cheaper fix. Or as bad as the tub bearing, a motor bearing.
Feb 26, 2010 | Maytag Washing Machines
Maytag Neptune front load washer model MAH3000AW, load during spin cycle
YOU MEAN LOUD DURING SPIN CYCLE? IF THAT SO, WHAT KIND OF NOISE? BANGING NOISE MEANS YOU HAVE UNBALANCED LOAD OR ONE OF THE SUSPENSION IS BAD OR FELL OFF. GRINDING NOISE MEANS YOU HAVE A BAD TUB BEARING, TO REPLACE THAT, YOU HAVE TO REPLACE THE WHOLE REAR TUB ASSEMBLY, VERY COSTLY. MEANS YOU PROBABLY BE BUYING A NEW WASHER.
BOYNISMO@YAHOO.COM OR 714-334-1998
Jan 14, 2010 | Maytag Washing Machines
Loud noise during spin cycle and agitator won't rotate
the machine is nknown to have bad main seals, in turn leading to the corrosion of the spin bearing, in which case makes it sound as if a helicopter is landing in your laundry room
Jan 26, 2009 | Amana LWA40A
Maytag Neptune Loud Spin Cycle
im sorry,load spin cycle may be a bad spin bearing.remove lower back panel.look behind large black pully.if see rust ,water.metal fragments.thats it.cost a bunch to repair.ive done them 4 400 to 500$.God bless you ,tom
Dec 28, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune Front Load Washer
No, I'll tell you before forking out $ $ for some bad news.The noise is your bearing. You have to replace the outer tub .Its not going to be repaired any other way.The idiots who designed this washer made this a non servicable bearing.The labor is high not to mention the outer tub is also.REPLACE THE OUTER TUB.
May 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
1,094 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
