Question about HP Officejet 4215v All-in-One Printer
Lines When I print there are lines on whatever I have printed. I think my roller needs cleaning, how do I do that?
This can be caused by another of things, but the 2 of the most common are faults with alignment or dirty rollers.
Thing to do first is run the cleaning routine and then alignment routine..
Clean the rollers with a dry clean cloth
Posted on Jan 07, 2008
Epson workforce 600 Horizontal White Lines
Your print heads may be clean, but it sounds like there is either a gouge in the heads one of the other components that touches the paper (transfer roller, imaging drum, whatever is on this model).
Dec 11, 2012 | Epson WorkForce 600 All-In-One InkJet...
Line through print
Perhaps did not specify paper thickness (check control panel and print driver).
Toner getting low.
Clean registration roller with clean damp cloth.
Aug 17, 2012 | Ricoh Aficio SP C811DN Laser Printer
Copies have black roller marks on the right side of each page, getting darker each time. I can print a single sheet, wait, it print again, wait~roller lines aren't as bad, but still present
I could be wrong, but I think it's in the toner cartridge. The drum - the roller that the image is formed on - has a soft, plastic blade rubbing against it to clean off excess toner after each print. If a clump of toner gets stuck under the blade, a line is printed down the page where that part of the drum isn't cleaned as well. Between prints, the drum keeps turning, and may be able to clean itself better than in a single revolution. It's a theory, anyway.
Pull out your toner cartridge and look at the drum to see if there's a black line around it at one end. You can't get to the cleaning blade without risking ruining the drum and the cartridge; the cure is just to get a new cartridge. If yours is fairly new, take it back to the store that sold it to you, along with a print sample. They might exchange it.
If the drum doesn't have a line around it, you can test it by deliberately jamming the machine. It's scary, but if you've unjammed jams before, you can do it again. Start a print job, then kill the power when you think the page is right in the middle of the printer. Open the printer and remove the toner cartridge. Look for that black line on the page before it reaches the drum, between the drum and the fuser, and past the fuser. (The fuser is the pair of hot rollers that pinch the page tightly and melt the powdered image into the paper. Any part of the image that hasn't made it into the fuser is still powder and will rub off.)
If the line doesn't show up until after the hot rollers, then I was wrong about the toner cartridge, and you're looking at a fuser problem.
Mar 11, 2011 | Samsung ML-2510 Laser Printer
I am getting lines down my paper like streaks when I print
Dirty print out is basically due to cartridge related issues. Take out the cartridge and clean its drum/ (green roller) with a dry, soft, lint-free cloth. The drum is usually located under a cover. Checkout for any spilled toner inside the printer and clean it also. Print a few pages so that the parts get further cleaned. I think, this would solve the issue.
Moreover, streaks (thicker lines) and dots etc indicate faulty PCR Roller which is located behind the green drum inside the cartridge. Cartridge or get the PCR Roller changed by a professional.
Let me know if any further clarification is required.
Dont forget to appreciate the solution if I could have been of any help!
Dec 27, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Brother MFC-6800 1. Prints with 3/8" blank vertical line down the entire page; 2. Prints with a couple of 1/16" blank vertical lines down the entire page; 3. Prints with some gray shadow...
This solution is unconventional but it worked for me. The black roller on my MFC had irregularities on it and was creating horrible printouts. I pulled out the drum and cartridge and cleaned the large black roller. I used furniture polish to make the roller very smooth. Now it prints really nice.
Nov 29, 2010 | Brother MFC 6800 All-In-One Laser Printer
Dell 5100cn printer printing yellow lines across the page.
This can be any of rthe following depending on the position iof the lines on the page. You need to establishe the position of the lines relative to the top of each page and this determines which of the following component will cause the problem
Dirty or damaged developer roller.
Dirty or damaged charging roller.
Dirty or damaged cleaning roller.
Dirty or damaged developer DSD wheels. These wheels are located on the outer ends of the color toner cartridge and appear as a black bushing.
Dirty or damaged transfer roller.
Dirty or damaged transfer drum.
All of them need inspecting and cleaning
Sep 23, 2009 | Dell 5100cn Laser Printer
Hp officejet, pro k5400 printer,when printing i get lines top to bottom on print,about 1 inch apart,tryed print head cleaning,changed the cartridges .need help ,top to bottom,only on...
That is ink or dirt on the rollers, you need to clean them by lifting the lid, as if you were putting new ink in, and wipeing the rollers that the paper runs through.
Jun 09, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Roller Marks
Try this to clean the rollers:
Put in blank sheets of paper in then print out from microsoft word a blank document.
This should clean the rollers. Also, there might be special cleaning sheets that you can purchase from Epson.
Oct 29, 2008 | Epson Stylus RX500 All-In-One InkJet...
Printed paper does not completely eject.
Sounds like you've got dirty rollers or paper chips stuck in the rollers. You'll have to inspect and remove what you find. You may use a rag with rubbing alcohol to clean rollers that have become glazed with whatever they get glazed with...dried ink and such.
Jan 05, 2008 | HP DeskJet 970cxi InkJet Printer
HP PSC 2355 Truncated lines
Try cleaning the paper rollers and the print head.
Use a wet cloth to clean the paper rollers.
Use a little amount of water and some alcohol (Isopropyl alcohol) to clean the print head. (You may not need to do this if your printer cleans it automatically through software utility.
This may be also have caused by the low ink level. Replacing the cartridge should solve this problem.
Oct 19, 2007 | HP PSC 2355 All-In-One InkJet Printer
HP Officejet 4215v All-in-One Printer Logo
73 people viewed this question
Ben Johnson
