No input from cable connection
The TV works with DVD player and playstation. No input from cable. Blank blue screen. RCA P60755AT
  • ProCase41 Jan 01, 2008
    Thanks alot. I was told that a VCR with a tuner would work...Is this correct? Also, do you know where to buy parts for this model? Thanks again.
  • 373 Answers
Sounds likely you have a bad tuner. If you have a cable box with your cable service and it is upgraded for video and audio rca jacks output you can run red white and yellow wires to tv input where the DVD is connected or additional jacks if available. This bypasses the tuner
Posted on Jan 01, 2008
  • TV Doctor
    TV Doctor Jan 02, 2008
    Yes a vcr with a tuner will work but then again since the tuner in the tv is bad you still have to use rca jacks if the vcr is equipped with them. Program the vcr tuner properly
  • TV Doctor
    As far as getting a tuner, If it is a ctc or ptk 179 as I remember well the tuner is integrated into the whole board and you cannot get the board anymore but might be fixed (rebuilt) at Tri-State Module. I don't have there number handy but can be found with search online.
When playing a DVD, I get sound but not a picture. The message on the screen is no input, check input. I have checked the cables at the DVD and at the TV and both are connected correctly, i.e. red to...
Have you tried using standard RCA AV cables? yellow-red-white - to TV. Or have you tried using an S-Video cable (a 5-pin mini DIN plug) between your DVD player and TV? if your TV has S-Video input, and your player has S-Video output, a cable for this should be easy to obtain and connect. Not expensive either.
Your TV should automatically detect the connection of S-Video (if it has this feature). S-Video is better quality than standard RCA yellow AV cable. (you can leave the existing component video connected)
You can also check your DVD player 'setup' maybe it is incorrect - make sure when using component video (red-green-blue) to set the player's output to progressive (for a TV that supports it) - unless it is already set to this.
If everything in the setup menu checks out OK, go with the cheap and easy S-Video cable suggestion. Radio Shack may sell these.
Apr 04, 2011 | Sony DVP-NS575P DVD Player
HOW TO PLAY DVD PLAYER WITH THE TV
Instructions Things You'll Need:
  • DVD
  • RCA, component, or HDMI cable(s)
  1. Decide what type of connection to use. Look at the back of your DVD player. It should at least have RCA (red, yellow, white) output ports. It may also have component out, S-video out, VGA out, or HDMI out. These connections vary in picture quality and price, HDMI being the most expensive and providing for the highest-quality picture. Whichever type of connection you decide to use, you also need to verify that you have the same connection on your TV. Flat screen TVs typically have more connection options than other types of TVs, so you should at least have component, RCA and HDMI inputs.
  2. Connect the DVD payer to the flat screen TV. Take one end of the cable or cables you decided to use and connect to the output on the DVD player. The other end should be connected to the corresponding input on the TV. Video input connections are usually found on the sides of flat screen TVs. Once the DVD player has been connected, you are ready to use your DVD player.
  3. Check DVD player functionality. Tune your TV to the input that you used for your DVD player by pressing the button on your remote labeled "input," "source," "TV/video," Source select," "TV/AV" or the like. For instance, if you used an HDMI cable plugged into your TV's "HDMI 1" input, press the input selection button until you see HDMI 1 on the screen. Power on the DVD player, insert a DVD into the player and press play and you should now see a feed from your DVD player.
Jan 17, 2011 | Panasonic Televison & Video
I Have just bought this reviever (Yamaha Rx-v365)and im just trying to work out how to best connect all my devises. I have Tivo, Lg DVD player with both yellow, red white cables and blue green red cable...
Hi, firstly some terminology:
yellow cable - video composite (worst quality)
white/red - stereo analog audio
blue/green/red - video component (second best quality after HDMI)
You are correct that RX-V365 doesn't do audio over HDMI. Moreover it also doesn't do any video processing, which means composite video input will go only to composite video output (and not to component); compoment input only to component output and HDMI input only to HDMI output.
If you have more devices of same video output (in your example the component blue/green/red), you can connect them to TV via the receiver. But if only one device of same video output, you can connect it directly to TV. There is no reason to go through your receiver for video.
For audio, you can use either the analog stereo white/red cables (rx365 has 5 such inputs) or better use digital SPDIF connection, which is slightly better quality and more importantly supports 5.1 sound. There are 2 types - coaxial (orange RCA plug, can use basic rca cable) and optical (square black connector). Receiver has 1x coax spdif input and 2x optical spdif inputs. Look at your other equipment to decide which cable to use.
For the analog audio inputs, I think you can assign it either to composite video or component video. So for DVD audio white/red plugs, you can choose if either Video composite yellow plug named DVD will be used, or component blue/green/red named DVD will be used.
Jan 03, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Have an RCA F27636BC TV. Can u hook a DVD player
How to hookup TV
If you have a TV with only a single coax input and you want to hook up components like DVD players and VCRs, here's how to do it.
What you need to connect your DVD player or game players to a TV that only has a VHF/UHF 75-ohm F-connector ("coax antenna input").
1.) RF Modulator with Stereo Audio Inputs.
2.) 6 foot long coaxial cable with male "F" connectors. This cable goes from the modulator to the TV. The modulator also has a coaxial input to plug in your antenna or your VCR.
3.) 6 foot long Video and Audio Cables with "RCA" plugs. The cables connect the yellow, red and white outputs from your DVD or game player to the yellow, red and white inputs of the modulator.
Works with X-Box, PlayStation, Nintendo or other devices that output audio/video via the RCA plugs and you want to connect them to your coaxial only TV.
Nov 24, 2009 | RCA F27636BC 27" TV
Which channel do i put the tv on, and which do i put the dvd player on in order for them to work together? I have a sanyo flat screen tv and a sony dolby digital dvd player, and i don't know how to get...
You do not put your TV on any channel. DVD players need to connect to a TV with video cables and not a RF cable. This means 3 connection options on how your DVD player should connect to your TV. First, since your DVD player is NOT a bluray player, then HDMI connection is not needed. 2nd, the best choice would be component cables. These are the RED/GREEN/BLUE RCA connector that are on the back of your DVD player. They got into the input of your TV that has the RED/GREEN/BLUE RCA connectors. These are your video connector. Now, you need to connect the audio. Look for the RED/WHITE analog audio connectors out of your DVD player. Connector those to your AUDIO RED/WHITE input of the TV. Power on the DVD player and then power on your TV. Press the SOURCE or INPUT button on the remote for the TV until you see the DVD on the TV....The second option is the connect your DVD player up to your TV with composite video, YELLOW/RED/WHITE cable...
May 16, 2009 | Sanyo DP32648 32 in. LCD TV
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
DVD player won't work on my 27gt615
alexa,
good day, if youre saying that you program the DVD to work on channel 2 or 4 does it mean you convert the signal of your dvd player from A/V output to RF out?
because the simpliest way to connect your DVD player to TV screen is by using RCA cable ( 3 wired cable being color marked as yellow/red/white) yellow = video red and white = audio
the connection would be: from dvd back part you'll see colored socket yello/red and white. connect the RCA to those socket following the same color .
and from the TV screen there should be A/V input socket. can be locate at the BACK/Side or FRONT of the screen marked as
"INPUT" ( AV1, AV2,AV3 if multiple inputs). Then select which input you want to place your DVD player ex.AV1 (from AV1 there will be 3 scoket in a row, yellow/red/white)
Connect the other end of your RCA cable following the same color code to TV "AV1 INPUT" yellow = yello/red =red/white=white. then from the remote commander of your TV screen locate a button marked as "TV/AV" or "A/V" press this button until the screen display switch to AV1.
cheers,
mark
Jan 31, 2009 | GE 27GT619 27" TV
No sound
tcolson,
good day, make sure your RCA red and white marked cable connected to TV screen audio input where you also connect your yellow cable which is the video.
note: always remember color code of RCA cable
yellow = video
red and white = audio (left and right)
connection would always be:
video device yellow RCA socket = TV yellow "INPUT" socket
white and red RCA = TV white and red "INPUT "socket
make sure that all this 3 cable are connected together in a specific "A/V input"
cheers ,
mark
Jan 30, 2009 | Sansui VRDVD4001 DVD Player/VCR
I'm confused how to connect my DVD player with the TV. which cables connect where. I dont have a user manual.
Mukhhe,
good day,to connect your DVD to TV screen follow this steps.
1) prepare your RCA cable ( 3 colored cable yellow/red/white)
note: always remember this
yellow = video
red and white = Audio (left and right)
2) at the back or front display of your TV screen you'll see RCA socket marked as "AV1 input" "AV2 input" etc... if your screen is only mono sound you can only see two sockets Yellow=video white= audio
3) at the back of your DVD player connect the RCA cable following the color code yellow to yellow white to white and red to red. after you connect the cable to your dvd player now connect the other end of thr RCA to your TV screen input.
make sure you'll connect it to "A/V input" not "A/V out" then after connecting all the cables, from the remote commander of your TV screen press a button indicating "A/V" some mark as "TV/AV" press this button until your screen display the back ground display of your DVD player.
cheers,
mark
Jan 30, 2009 | Spectroniq PDV-70X
Blue screen on all channels RCA TruFlat
This is NOT the problem. video games, dvd player and cable connection are all all a blue screen with sound
May 14, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
