New sanyo tv goes off suddenly, then back on. i think the cable being used for antenea is hooked to satelite, but we dont have the service. still get local channels though.
the tv is brand new. our old tv did the same thing then eventually wouldnt turn on at all.
Removed any magneting material near your tv or any electronic material near you tv specially speakers,, turn it on for 1 min. then turn it off for 5 mins. 4 times..
First off, you need to hook up audio and video by using an A/V cable to connect the DVD player to the TV, yellow, white and red jacks are coded, match the jacks up, put one end of A/V cable to DVD player OUTPUT jacks and the other end to INPUT jacks in back of TV. Also same with Direct TV receiver, hook top set of jacks to TV, with A/V cable, also connect coaxial cable from satelite to matching satelite input jack. Connect power cables, and then you're set. Good luck to you!
U can't hook the satelite signal to the PLaystation 2.The satelite hook up to the main in the Antana input.The playstation 2 must use the RCA cable came with the Playstation 2 hook up in any Audio,Video in put in the the tv.Tune in what input u hook up like 1,2,3,extra..use ur Playstation 2.
sound like a tuner problem. there is a resistor that goes to the tuner that could of went bad 39,000 ohms i think which should have a orange white orang strips around it and a gold. anyway there is a problem with tuner. Sanyo was good about haveing a problem with tuners in there smaller sets. If you do not know anything about how to repair you probly shoud take to a shop but the total cost might be high and not worth it in the long run. think before you jump still water runs deep.
Ok if you want to hook up RCA cables to that TV and dont have a adapter you can buy a RF MODULATOR ( Wall-mart / radio shack for $20.00) and use that to conect to TV and the ps2 will connect to that ( this will also let you use a DVD player with the TV!)
Instructions in RF package!
PLEASE RATE THIS RESPONSE AND HELP KEEP THIS SITE FREE!
THANK YOU!
do you have your converter box hooked up to an antenea? If so, if you move the antenea, then you may have to reprogram the channels through the converter box. This happened to us. So, we played around with the antenea until we found the most channels came through and marked the area around the antenea (you can use tape, or if you do not care a permanet marker like us. Note our antenea sits on top of our tv.) We have not had any trouble since. We marked the place for the antenea, in case someone moves it or so we can try to get more channels when the final switch happens. We gain a lot of stations, but lost only one.
If you hooked up the satelite box to your tv Automaticly the Satelite box is the one who pick up the channels (from the satelite)
In this case your tv is acting as a monitor only. Try to connect your tv with HDMI cable or COMPONENT cable for best picture. Don't use RF antenna input to hook up your Satelite Box. Hope this Helps
J
I unhooked the new tv and hooked up the old one to see what channel it was on and then rehooked up the new tv and put it on the same channel as the old one.This worked but I also had to put the cable into the hook up on the back marked cable instead of the one marked HDTV.
If you're not on cable or satellite, you will need an antenna to get off-the-air reception. This TV does not have a DTV tuner, so you will also need the converter box. Depending on how far you are from the broadcasters' transmitters, you might be able to get away with an indoor antenna. Or you might find that you get few channels with the inside antenna and then you'll need something outdoors. There are a number of styles to choose from.
The antenna hooks to the converter box, and the converter box then goes to the TV. It can be hooked to the TV's "ANTENNA" connector. This should be covered in the set's manual where it shows you how to connect a regular antenna. With the box, your TV will always stay on channel 3 or 4 (depends on how you set up the box) and you'll change channels on the converter.
You can also connect the converter to the TV with audio and video cables like you would a DVD player. Most of the "coupon-eligible" converter boxes include direct video and audio output jacks. This gives you better picture and sound quality than by hooking it to the TV's antenna input.
Hooking up a converter box is like going back in time to when cable TV was new and you had to get a converter box from your cable company. Same way of hooking it up. Hope this helps!
