One stove top burner, when turned off, keeps igniting. I've made sure the ignition is dry. I have to unplug the electricity for the ignition to stop. Any ideas? Joe
first make sure all switches are off if still have the problem then you will need to replace the igniters switches on the range they usually come in sets of four and clip to the front the burner switches just remove the cover on the switches and you will see
Was this solution helpful? Show your Appreciation by rating it:
I have a Kitchenaid Model KGCT365x and need to replace the igniter switch on the front right burner. Can this be done through the knock hole or does the whol glass top have to be removed? If it has to be removed, what is the best procedure to do this?
