Question about Philips 37PF7320A 37 in. HD-Ready LCD Television
Menu screen wont go away
My philips 37pf9631d turns on my its self and the menu screen pops up and wont go away. any idea what the problem might be
  • 106 Answers
Try to replace the key pad board on the side or the remote sensor board on the bottom. they are small boards and cheap. If that won't work, you need to replace the Small Signal Board (SSD Assy), which is quite expensive.
Posted on Jan 01, 2008
  • LX Jiang
    LX Jiang Jan 01, 2008
    First try to download the latest software from Philips' Website for your tv. It may solve your problem as well. IF it doesn't work, do the hardware troubleshoot as mentioned above.
My panasonic tv model TC32LX85 N has self check and wont go away?
To Exit Self-check Screen
  • Press and Hold Power button on the TV for 5 seconds [or] disconnect the AC cord from wall socket.
TV volume down and OK on the remote only does a basic IC self check. It do not rest the TV. It do not clear channel programmed settings, picture settings, channel labels, lock settings or password. Using this method, it shows the units' firmware version [Peaks 1.050 and GenX 1.00] and it checks the IC communications only. This is more useful to identify the firmware version, without having to decode the info in the setup menu about version/screen.
  • To make a reset to TV, turn it ON while pressing the [Volume-ve] button on the main unit, and press the 'Menu' button on the remote control for more than 3 seconds. The self check menu appear on the screen. Then disconnect the AC cord from the wall outlet. [ALL PROGRAMMED PARAMETERS WILL BE ERASED]
Jul 30, 2014 | Panasonic TC-32LX85 LCD TV
Cannot exit menu
I had the same problem with the menu, cannot exit and it keeps popping up, Took out the cable to the TV, clean it and somehow it works.
Sep 01, 2011 | Philips 37PF9631D 37 in. LCD HDTV
Contrast/Brightness Menu repeatedly pops on screen/won't go away
What kind of system do you have there? Regular PC + monitor or All-in-one/Laptop?
Dec 30, 2017 | Dell E172FP 17" LCD Flat Panel Monitor
My menu screen keeps popping up and wont go away
Unplug,replug about hour later,let see if it reset itself,see if it go away.Not the manual controllers board is dead,the board in the right of the tv.
Dec 14, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Menu Screen keeps popping up, interrupting cable stream on tv
You have it in the demo mode go into menu and turn it off.
Aug 06, 2009 | Televison & Video
Menu Screen Keeps Coming up on the screen
The most commom causes are One. There ia a stuck button on the tv itself. The Menu button. The membrane switch or the TACT switch is bad and needs to be replaced. The Main bd can also be bad.
Jul 16, 2009 | Philips 42PF9630A 42 in. Plasma Television
Menu pop up
needs sft waer update call philips
Jun 02, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Your DB is corrupt. Download the newest version of the Philips Device Manager for your model # at, and then click the "Update" function once it is installed. The update wil lresolve your issue.
-Tha Mp3 Doctor
Mar 16, 2009 | Philips SA5125/37 MP3 Player
Menu screen won't go away.
Try to hard reset the tv..Leave it unplugged for 4-6 hours and then plug it again and use..If this did not help Try to contact a service centre or service person because this is probably a hardware problem which definetly needs service and replacement!!...Thank you..
Hope this helps you....
Kind Regards!!
Jul 21, 2008 | Philips 50PF7320A 50 in. Plasma HDTV
Philips 37PF7320A 37 in. HD-Ready LCD Television Logo
170 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
