Amana ARB1917CSR Bottom Freezer Refrigerator
Problem for Amana ARB1917CSR Bottom Freezer Refrigerator
Fridge not cooling...
By isle_of_spic on Oct 26, 2009
Fridge not cooling... Tried adjusting temp to max cool and nothing. Unblocked vents, still nothing... About to try pulling off back panel cover to vacuum and brush... but sure I will still get nothing... help???
Comments:
Oct 26, 2009
- In case I didn't mention, the fridge is an Amana ARB1917CSR... (w/no Ice Maker installed) Also, the freezer works... The fridge has 3 fans at which the back bottom fan works, the freezer fan works, but the fridge fan does not.
Best Solution
posted on Oct 26, 2009
Very Helpful)
steve_con
Rank: Guru
Rating: 91%, 99 votes
This sounds like a problem with the defrost circuit. It is likely that the evaporator coil is clogged with ice due to the defrost heater not functioning. This can be caused by a failure of any one or more of the following components:
1) Defrost timer. Defrost timer may be "stuck" - failing to advance from a cooling cycle to a defrost cycle. May be found in the toe space of many fridges, but not all.
2) Defrost terminator. This is a thermal sensor that is secured to the refrigerant line close to the evaporator coil in / behind the freezer compartment. If this component fails to detect a rising temperature, it never allows the fridge to return to the cooling mode again.
3) Defroster Heating coil. This is a simple, relatively low wattage heater secured to or near the evaporator coil. It is powered through the defrost timer and shut off by the defrost terminator. If the coil is burned out or otherwise "open", it will not heat to melt ice buildup on the evaporator coil.
4) Fan. The fan is located near the evaporator coil. if the fan is unable move air from the freezer to the fridge, the compressor runs endlessly because cold air is not blown into the fridge compartment - where the thermostat is detecting a high temperature.
5) Condenser coil. If the condenser has a "furry jacket" it's long overdue for a cleaning. Gently vacuum lint / dust / dirt collected on the coil to increase efficiency. This is probably not the problem - but it probably needs to be done anyway.
Most of these steps will require hand tools, schematics (specific to your model), electrical test equipment, etc. Be careful to not use sharp instruments that may puncture refrigerant lines or electrical insulation. Allow the ice to defrost with the fridge powered off with the freezer door opened, and a pot of hot water inside, hair dryer directed at the coil, etc. Access to the evaporator coil is usually from the freezer compartment (back wall) and will require removal of any ice maker installed.
Comments:
Oct 26, 2009
- A few links to help you out.
Exploded parts diagram for your fridge:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5167592
Generic service manual for Amana bottom mount freezer / fridges:
http://www.servicematters.com/maytag_library/docs/S120_0R0.pdf
http://www.servicematters.com/maytag_library/docs/T120_0R0.pdf
Was this helpful?
Yes
No
2 people thought this was helpful
Asker's Testimonial
" sorry, no fan in freezer... so only 2 " - isle_of_spic
Popular Solutions for Amana ARB1917CSR Bottom
Questions and Unsolved Problems for Amana ARB1917CSR Bottom
Do you recommend Amana ARB1917CSR Bottom Freezer Refrigerator?
Answer
Answer
There are two water lines coming out of the back of the fridge. One of them appears to be an over... (More)
Answer
my frost free fridge freezer was working fine then started making audible clicking noises then... (More)
Answer
buzzing noise, no ice maker, freezer does not freeze... vacuumed out vents and back... had service... (More)
Answer
Recently our Amana fridge only makes about 8-10 ice cubes and never stocks ice in the bin as we use... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Amana ARB1917CSR Bottom...:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(816) 471-5334
* Please Contact us for More Information
At Your Service Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
