Maytag Atlantis MAV6000 Top Load Washer
Problem for Maytag Atlantis MAV6000 Top Load Washer
Smoke and a burning smell coming from washer, wont spin water out
By linda_hockin on Oct 26, 2009
smoke and a burning smell coming from washer, wont spin water out
Solution #1
posted on Oct 26, 2009
Not Rated)
57 varieties
Rank: Guru  Washers & Dryers  Expert
Rating: 88%, 551 votes
Do the following.
  1. Switch off the machine and disconnect the mains power and Turn off the water supply to the machine.
  2. Remove the access panel on the lower right front of the machine.
3. Remove the filter and make sure that the filter is not blocked and is clean and clear of all debris. Clean as required. Note that depending on the machine type you may get a lot of water coming out of the filter when you remove it if the machine has not drained successfully. Note that if the machine has stopped and not fully drained then you may be able to drain out the excess water by removing or disconnecting the waste hose and laying it on the ground in a tray. It may take a few minutes to empty but it will save a small flood.
4. Proceed by checking the drain hose for proper connection and kinks and make sure that it is not blocked.
5. Also check that the main waste drain pipe, if you use one, is not blocked and clean if required.
6. Reconnect the power and switch the machine on.
If the problem persists then do the following.
7. Switch off the machine and disconnect the mains power.
8. Check the electrical connections at the pump and make sure it is operational.
9. Remove the connecting hoses, and expect water to drain out and make sure the pipes are not blocked with debris or any object blockage.
10. Makes sure the pump appears clear and that the impeller looks in good condition.
11. Reconnect the hoses and then reconnect power and switch the machine on.
12. If problem has not been corrected, then remove the pump and check that the drive coupling to the motor is OK and that the motor turns OK. If all is well then replace the pump.
The smell may well be coming from the motor if it is overleaded or has a problem. If the above does not solve the issue then you may be looking at the replacement of the motor.
Was this helpful?
Yes
No
Popular Solutions for Maytag Atlantis MAV6000 Top
Questions and Unsolved Problems for Maytag Atlantis MAV6000 Top
Do you recommend Maytag Atlantis MAV6000 Top Load Washer?
Answer
Answer
The washer fills with water and stops when at the correct fill level, but doesn't start agitating or... (More)
Answer
I think filters need cleaning as clothes covered in lindt and clothes not being washed properly.... (More)
Answer
My MayTag Atlantis Washer is not dispensing fabric softener during rinse cycle. Soap is not... (More)
Answer
maytag washer atlantis not working, not spining, power trips, and smells like burning rubber.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing... Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
