Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Problem for Jenn-Air SVE47100 Slide-In Electric Kitchen Range
Oven does not heat
By downtown_556 on Oct 26, 2009
Oven does not heat.
After setting heat to any level preheating sign comes on but temperature stays at 100 and element does not get hot.
Solution #1
posted on Oct 26, 2009
Not Rated)
milten1
Rank: Guru  Jenn-Air Ovens & Ranges  Expert
Rating: 90%, 483 votes
if you can check to make sure you have 220v ad the termila post on the back of the range
then ohm out your element , it should read continuity
but i can be almost 100 percent sure you will need to replace that element
www.appliancepartspros.com
type in your model numder move down to the oven section and you should see your element and cost
hope this helps
Was this helpful?
Yes
No
Popular Solutions for Jenn-Air SVE47100 Slide-In
Questions and Unsolved Problems for Jenn-Air SVE47100 Slide-In
Do you recommend Jenn-Air SVE47100 Slide-In Electric Kitchen Range?
Answer
Answer
when i try to turn my oven on it reads "feature not available" whats wrong with my over?
Answer
F I appears on screen along with a beeping noise after oven is turned off
Answer
all digital gauges are blank. Oven light works as does fan, burners.
Answer
Had to clean my oven because of a pie spill. Now a fan continues to blow and the oven won't turn on.... (More)
Answer
Trying to self clean oven F-9 code comes on with a beeping sound. What do I do?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Jenn-Air SVE47100 Slide-In...:
Top Kitchen Range Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Kitchen Range Experts
Top Range & Oven Repair
(972) 859-0929
Honest, Dependable, Available &...
Accurate Appliance Repair & Parts Supply
(423) 303-3784
Oven and Range parts delivered overnight...
 Appliance Parts Pros.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
