Question about SanDisk Sansa e250 MP3 Player
Charging the Sansa Clip player
How can I tell when my Clip player is fully charged? Does the "Connected" message change to something else when it is done? How long should this take. I'm not finding this in the very brief set of instructions. Thank you.
  • 758 Answers
If you leave your Sansa plugged into your charging source (wall charger, computer, car etc.), your player might still remain fully charged and just on. If you can, you may want to just leave it plugged into your charging source until you want to use it, so it stays fully charged.When its done, it will say fully charge...it should take a couple hours to charge the device....
Also, does your player have an auto power off or idle sleep setting? You can use this setting to set the amount of time you want your Sansa to automatically turn off after you don't use or listen to music on it.
Posted on Jan 03, 2008
How do I know the sandisk is fully charged
I just bought a Sansa 8GB Clip, when the battery is completely charged the yellow battery icon (at the top right of the screen, to the right of "Connected") stays solid and is not animated, with the center horizontal bar completely filling the inner section of the icon. While it is charging the center horizontal bar is animated and slides from right to left. At no time does my battery icon turn green.
Jan 19, 2011 | SanDisk Sansa Clip MP3 Player
My Sansa Clip MP3 Player is almost new, however the battery only last about 3-4 hours from fully charged. But now it appears to be completly dead which my computer will not even recognize it to start the...
Hey, greatings from lithuania
i have the same problem. Couple days ago i changed the battery from another sansa clip ant it worked fine, pc recognized sansa again :/ i think that the battery is dead , detailier the microchip wich is on the battery..
Oct 26, 2010 | SanDisk Sansa Clip MP3 Player
My sansa clip was working yesterday and when i woke up i turned it on and the lights started blinking and it shut down what do i do?
Try Fully charging the most electrical equiptment have a reserve built in its battery so you are able to switch on by going off again Batteries need fully charging. If you have done this then your battery does not hold its charge Sorry but they need replacing.
May 22, 2010 | SanDisk Sansa Clip MP3 Player
My sansa clip won't charge sometimes. it will display the "connected" screen and a fully charged battery but when i unplug it, it will tell me that battery is low!
Hello
first you have dirty battery terminal and need to clean, second you have weak battery and need to replace a new one...
Angel
Thanks...
Jul 31, 2009 | SanDisk Sansa Clip MP3 Player
Sansa fuze of 4gb wont charge
Hi
I have sansa clip which i believe behave the same it never says charging it always says connected but that does not mean it is not charging .
leave your sansa connected for a while and then see if the battery meter has changed .
hope it helps
Enjoy
Jul 17, 2009 | SanDisk Sansa Fuze MP3 Player
My sanDisk Sansa Clip MP3 Player will not charge anymore. At least not on the computer I'm on. I have had it hooked up to charge for 2 days now and nothing. Why is this and how can I charge it?
This is direct from the sansa FAQs at http://www.sansa.com/support/sansa_clip/faqs 02. Why won’t my Sansa Clip charge when I connect it to my computer? USB Cable
Make sure that the USB cable is properly plugged in and use the original cable.
Computer in Hibernation mode
Make sure that the computer isn’t entering hibernate or sleep mode while the device is connected. The computer must be on in order to charge your player.
USB Port 2.0
Make sure your player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
Battery
Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware
Make sure to update firmware by downloading and installing the Sansa Firmware Updater.
I hope this helps, and don't forget to rate the answer.
Mar 05, 2009 | SanDisk Sansa Clip MP3 Player
Sansa clip wont power up unless hooked up to usb
http://www.sandisk.com/media/175960/clip_um_0608_eng.pdf
Windows XP SP2
• Windows Media Player v10
• Intel Pentium class PC or higher
• CD-ROM drive
• USB 2.0 port for hi-speed transfers and charging
Make sure HOLD button is not on.
Battery
The Sansa
Clip player comes with an internal rechargeable battery. To use the player for
the very first time, remember to fully charge the battery. You can charge your Sansa
player through the USB port of your computer, a car adapter (not included) USB port, or AC
adapter (not included) USB port.
Charging
To charge the battery, please follow these steps:
1. Connect the larger end of the USB cable into an available USB port on the
computer.
2. Connect the smaller end of the USB cable into the Sansa
Clip player.
3. The computer must be on for most USB ports to charge your battery. Your
Sansa
will show connected and the yellow charging indicator will appear.
The battery level indicator will blink while charging. You will not be able to
play while connected to the computer USB.
4. To stop recharging, simply disconnect the cable.
The battery can also be charged using an AC adapter (not included) or a car adapter
(not included) and you will be able to play your device while charging with one of the
adapters.
NOTE: Some low-power USB ports may not be able to provide enough charge
power. Also note that the rechargeable batteries are not replaceable.
Feb 26, 2009 | SanDisk Sansa m200 SDMX3-512 MP3 Player
When i connect my sansa clip 2gb it will not charge. it say connected and then goes off. I thought it was charging but when i checked it the battery had died what do you suggest i do to get it working...
Check for the following:
USB Cable
Make sure the computer isn’t entering hibernate or sleep mode while the device is connected.  The computer must be on in order to charge your player.
USB Port 2.0
Make sure the player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Battery
Latest firmware
Jan 23, 2009 | SanDisk Sansa e250 MP3 Player
Sansa Clip not holding charge
Locking the player will not allow the player to charge properly, no matter how long you have it plugged in.
Dec 17, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa e250 MP3 Player Logo
164 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
