Back to:
Tags:
RIM BlackBerry  Pearl  8100
Craftsman Air Compressor (by 6 users)
posted by vglen on Jan 01, 2008
My craftsman air compressor will only pump to 40/45 psi and it takes several minutes for this even. The pump broke and I feel the reason was due to extended running and never pressuring up to full psi to shut off. I have rebuilt the pump and feel like it is ok now. Any Suggestions?
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
5 Other Users Have The Same Problem
Comment by misstrooper, posted on Sep 15, 2008
I have a 1.5 horsepower 15 gallon air upright air compressor. It comes on and runs fine, but it will only pump up to 30 lbs of pressure. I have replaced the pressure swith and cleaned the check valve. Still no luck. I need help. Of course it is only one year old, but still out of warranty.
Comment by Guest, posted on Aug 08, 2008
I HAVE AT CRAFTSMAN 30 GAL AIR COMPRESSOR... IT PUMPS UP TO 40 TO 45 PSI AND WONT GO ANY HIGHER.. THE TUBE THAT GOES TO THE TANK FROM THE ON OFF SWITCH ARRANGEMENT GETS WARM AND EVEN HOT TO THE TOUCH... WOULD APPRECIATE ANY INFO ON REPAIRING IT... THANKS
Comment by Guest, posted on Aug 01, 2008
HAVE THE SAME PROBLEM BUT MINE WILL PUMP UP TO 60 PSI
Comment by Guest, posted on Jul 26, 2008
My craftsman 1hp model# 921-153100 Starts and builds pressure to 125lbs, after I blow the pressure down it starts up and goes to about 35lbs and shuts off. Cylinder head is hot. Possible running capacitor 40uf??. Checked with Sears they want too much to repair, I paid $99.00 for it.
Comment by leegresh, posted on Jul 22, 2008
Craftsman 1hp 4 gal model no# 921.166380
will run to 125psi one time. After I use it one time it will not go back to 125psi it will only go to 25psi and then shut down (This is Brand new)
Solution #1
posted on Jan 01, 2008
Not Rated (0)
skeater
Rank:Master Master
Rating: 92%, 27 votes
may need to check the adjustment on presure relief valve on tank or check pop off valve on the top of the pump head.there may be some debree stuck in valve.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Craftsman Air Compressor:
I don't want to Accept this solution
Can you Help with these PDAs problems?
i am trying to download some applications off of my PC. i...
Hi Has anyone had the problem with having to remove /...
I have a blackberry pearl 8100 and need to unlock it I...
my blackberry does not work it can't open ,no image I SEE...
my phone key pad has locked and asks for puk code.
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
