Refrigerators
Generic problem for all Refrigerators
Periodic tripping of earth leakage switch.
posted by ando2 on Jan 01, 2008
Our Kelvinator Impression Series 640L side by side fridge freezer (approx 10 years old) has started to periodically trip the earth leakage switch. It appears to be possibly during the defrost cycle, however I'm unsure of this. I wondered if it may be thermostat, defrost part, or a fan or element problem. Could only happen on New Year's Day! I would appreciate any suggestion or advice you could give. Cheers - Happy New Year.
Ando.
andos2@bigpond.net.au
Comment posted on Jan 07, 2008
Thanks, but this is in Australia and earth leakage units are the norm. However, I think I have solved the problem - maybe! There is a damaged door seal and there was ice formlng around the earthed/electrical area within the cavity of the freezing/defrost area. Have decided to renew the seal, and apply insulation foam to both door cavities and see what transpires. I am in awe that in this mellenium manufacturers still don't apply insulation to the cavities of their fridge/freezer doors!
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Jan 01, 2008
Thanks for Trying (70)
tech17
Rank:Guru Guru
Rating: 88%, 1149 votes
your not supposed to run an appliance on a ground fault circuit because most of the components ground to the body og unit do you have it on a gcfi well here in america anyway
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Periodic tripping of earth leakage switch.:
I don't want to Accept this solution
Can you Help with these Refrigerators problems?
Frigidaire FRS26R4A Side by Side...
I have a Frigidaire Refrigerator (side by side) - and both...
Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
water is working, corkscrew to push ice is working, ice is...
Fisher and Paykel Active Smart E522B Bottom...
The channel (in the fridge compartment) that collects the...
Refrigerators
G.E. Monogram Refrigerators/Freezer - Refrig temp goes too...
Loading problems.
Need Immediate Assistance?
Chat Live Now!
Repair Service
Find Refrigerator Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
