Question about E-Machines eMachines Desktop PC
Emachine model t3302 ethernet card
My daughters computer has Realtek RTL 8139/810x family fast ethernet NIC What card do i need to give her wireless connection and where to buy?
  • 2,351 Answers
Re: emachine model t3302 ethernet card
This is how the wireless world works. You buy a wireless router with a four port switch. Your DSL or cable connects to that. A cable called a Rj45 connects the DSL or cable to the back of the wireless router. You also buy a wireless network card for your PC. After running the software for the router & the wireless nic card including setting up a home network through windows your daughter will be able to connect that computer to your network from any room in the house. Below is a link to a wireless router:
You can connect up to four computers to the wirless router. A computer that does not connect to the router by a Rj45 must use a wireless network card. Linksys WMP54G Wireless-G PCI Adapter Retail:
As you will see there is a big differance between a NIC card & a wireless card.
Posted on Jan 01, 2008
0 characters
3 Points
I've downloaded the Realtech driver version 6.110 but it won't work after installing it. I contacted Asus tech support but they said Windows 2008 Server isn't supported on this box.
You might just need another driver either a lesser model no or a later model ethernet driver no.
if these packages are not the right
On the home page you should see a search tab just type in what you are looking for
tick in the box for windows software or all software box
IE: Motherboard name wireless or Ethernet driver
you might have to try a few times to get it right
hope this helps
Nov 11, 2012 | ASUS Eee Box EB1501P-B016E Nettop PC -...
Ethernet controller missing hp compaq dx2200
That's probably why you've 2 network cards on your computer. Check is it's so, then connect your cable to the other connector and your network connection will work.
You can see in the control panel under network connection if you have to connection.
The card with the yellow question mark need drivers. For that check that on the vendor website.
Aug 06, 2012 | HP Compaq dx2200 PC Desktop
I need NIC drivers for a compaq computer
Realtek LAN DriverThis is the Type which is installed on your PC
Realtek RTL8169/8110 Family PCI Gigabit Ethernet NIC
Realtek RTL8168/8111 Family PCI-E Gigabit Ethernet NIC
Realtek RTL8101 Family PCI-E Fast Ethernet NIC
For Vista 32-bit
Click Here to Download the driver
For Vista 64-bit
Click Here These links are From Official Compaq site.Unfortunately there are is no download option for XP and Windows 7 on Compaq site.
so use the below link directly from Realtek
Click Here Try this first if this driver don't work use this it should get installed- Realtek Official site Choose Windows and Download the appropriate one according to your operating system. Here you have for all versions of windows.
Feb 04, 2011 | HP Compaq Presario SR5350F Desktop PC...
Need new Ethernet drivers.
Without getting onto the internet, you're not going to be able to get the driver from them.
Your best bet is to get onto a computer at a friend's or library, and download the driver to a flash drive.
Once you get home, you can install it. In checking, Realtek appears to have all the current Vista compatible drivers available on their website.
Mar 19, 2009 | HP Media Center m1170n Photosmart PC...
Need to find network driver
i) Click on  Start button ---->Select option Control Panel------>Select Network Connections----->
   a new window appears showing the "internet connections icon " Such as:
   Local Area Connection 1 or 2 or 3 and since you are not connected it will show this icon as:
eg1:   Local Area Connection 1 or 2 or 3
       Network Cable Unplugged, Firewalled
       VIA compatible Fast Ethernet
   in this case u can download VIA network drivers....from internet..
  eg2:  Local Area Connection 1 or 2 or 3
          Realtek RTL8139 Family Fast Ethernet NIC
   in this u can download "Realtek RTL8139" network  drivers.... from internet(which is showing model    no: RTL8139 through google search engine )
ii) Click Start button ---->Select RUN option ----> type in the text box    devmgmt.msc  --->Select Network Adapters....
but this will show wheter ur network adapter or NIC is VIA or Realtek or......but does show the correct Model NO: of VIA or Realtek....
so i would suggest to follow the step (i)
Thanking you
Dec 27, 2008 | E-Machines eMachines Refurbished EMA...
9/2007 my daughter purchased a Gateway notebook and a Netgear router. She opted to not secure the network through the router at that time. I recently purchased a Gateway notebook and am using my daughter's...
It sounds like you need to reinstall the driver for the Realtek network interface card (NIC). I recommend accessing the Gateway web site to find the model number of the laptop, and then download the driver for the Realtek NIC. This should restore the functionality.
Oct 04, 2008 | Gateway PC Desktops
Internet Connectivity
this sounds like a faults network module on your motherboard you should take it back to your place of purchase a get a waranty job or a exchange
Jul 03, 2008 | E-Machines eMachines Desktop PC
Emachine model T3302 desktop ethernet question
The "Realtek RTL 8139/810X family fast Ethernet NIC card" is a wired networking device. What you need is a WiFi Networking which can either be a PCI card (you need to open the PC and physically mount it inside) or perhaps the easiest, is to get a USB WiFi. There are so many brands, models and versions available and just about any would work. You need to verify though that the USB WiFi is compatible with your daughter PC's operating System (XP or Vista). Some known good brands are LinSys, DLink, NetGear. Some models/versions are simple gadgets that they look like a thumb/flash drive while others have a USB cable with a tabletop mount/rack/cradle.
Such can be bought from any computer shoppe/store. Most models come with an instruction/installer/driver CD that you need to run first before plugging in the WiFi USB.
If you already have an existing DSL account that connects to the Realtek, you would also need to get a Wireless AP/Router. It would probably be easier if you get a match pair (same brand)
If this is a completely new DSL WiFi setup, you need to get in touch with any WiFi Provider in your area. Most would provide a free USB WiFi Adapter if you subscribe to them so there would be no need to buy the USB WiFi adapter nor the Wireless AP/Router.
Hope this be of some help/idea. Pls post back how things turn out or should you need additional information.
Good luck and kind regards.
Jan 01, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
236 people viewed this question
Top E-Machines PC Desktops Experts
Brian Sullivan
Brian Sullivan
Michael Thomas
Michael Thomas
Are you an E-Machines PC Desktop Expert? Answer questions, earn points and help others
