Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
Air Filter message
Message that we need to clean air filter comes up. We clean the filter but it will not let us press yes that we clean it. Also the temp light keeps blinking. We replaced the bulb in August 2007.
where is the filter located?
  • Anonymous Feb 13, 2008
    I have the same problem with my pt-43lc14. The fan will run for hours after the tv shuts off unless you unplug it.
    Problem Solver:
  • 37 Answers
Ok you know i would just take it back with the warrenty but heres what i think you should do in the manuel there should be a help line from that brand they should able to help more then me but there should be a compartment at the back where the filter is located if you need anymore help contact me at mid.nightclub@hotmail.com
Posted on Jan 01, 2008
Air filter message on screen
Check your user manual (download if not available) under "cleaning the air filter". It will give instructions on how to reset the filter and remove the message.
Jan 06, 2014 | Televison & Video
Reset air filter
Page 58 of the user manual says that after cleaning the filter when the power is turned on, you will be given the opportunity to reply "Yes" to the question "Did you clean the filter". I suggest you go through the motions of cleaning the filter again, removing the necessary parts. Then replace the parts, turn the power on, and watch carefully for the message "Did you clean the filter".
Jan 06, 2014 | Panasonic PT-40LC12 40" Rear Projection...
Clean filter message reset
the filter will need to be cleaned and if the set still shuts down then I would suspect the fan may need to be cleaned and possibly replaced.
Aug 07, 2012 | Panasonic PT-43LC14 43" Rear Projection...
After turning on the projector, I get a message that says clean the filter and reset the timer. How do I do that? I have cleaned the filter.
Procedure for resetting filter time.
Pressing the RESET button for about 3 seconds displays the FILTER TIME menu. Select the RESET using button to reset the timer. : RESET <- CANCEL Selecting the RESET resets the count of the lamp timer to 0. memo Perform this function only when you have cleaned or replaced the air filter. The filter timer counts the used time of the air filter after cleaning or replacement, to display the messages about the air filter. Incorrect performing causes incorrect operation of the messages. memo About caring for the air filter, please refer to the section "Air Filter".
Users manual located here. http://www.aboutprojectors.com/pdf/hitachi-cp-x1250-manual.pdf
Good info deserves a good thumbs up! Thank you!
Mar 01, 2011 | Hitachi CP-X1250 Multimedia Projector
Fresh air is reading perform cleaning. exactly what does that mean,I cleaned the filter and the plate but it stii reads perform cleaning.HOW
After you have cleaned the filter and plate, reassemble the purifier. Plug it in, turn it on, when the message perform cleaning reappears, press the Reminder Reset button on the purifier to clear the message. Now you are good to go for another 30 days.
Feb 22, 2010 | Ecoquest Fresh Air Air Purifier
My hitachi cpx201 projector says to check the air flow
Hi There Teacher!
the air filter unclips on the left hand side, lens facing out.
after vacumming out the filter see below for filter reset counter procedure
Good Luck!
Turn the projector on and reset the filter time using the FILTER TIME item in the EASY MENU. Before taking care of the air filter, make sure the power switch is off and the power cable is not plugged in, then allow the projector to cool sufficiently. Taking care of the air filter in a high temperature state of the projector could cause an electric shock, a burn or malfunction to the projector. Use only the air filter of the specified type. Do not use the projector without the air filter or the filter cover. It could result in a fire or malfunction to the projector. Clean the air filter periodically. If the air filter becomes clogged by dust or the like, internal temperatures rise and could cause a fire, a burn or malfunction to the projector. WARNING Please replace the air filter when it is damaged or too soiled. When you replace the projection lamp, please replace the air filter . An air filter of specified type will come together with a replacement lamp for this projector . Please reset the filter time only when you have cleaned or replaced the air filter, for a suitable indication about the air filter. The projector may display the message such as ?gCHECK THE AIR FLOW?h or turn off the projector, to prevent the internal heat level rising. NOTE (1) Press the MENU button to display a menu. (2) Point at the FILTER TIME using the ??/?? button, then press the button. A dialog will appear. (3) Press the ?? button to select RESET on the dialog. It performs resetting the filter time.
Jan 14, 2010 | Hitachi CP-X201 Projector
How we can clean airfilter because message is appearing regarding clean your air filter
check in the menu to see if there is a filter timer that you can reset. if so, reset it. if not, there is an air flow sensor on the projector that will send that message if the air flow is decreased so the projector does not overheat. find the filter and remove it. blow it out with canned air and blow out the projector as well. replace the filter and enjoy!
Nov 05, 2009 | 3M X50 Multimedia Projector
Temp light flashing and air filter message
there are 2 cooling fans one or both of them may need replaced,
Jan 20, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Air filter
air filter message is ussally generated by a tempsensor getting hot. could indicat falulty sensor.. is the fan running. a stalled fan could cause the problem but usaally when that happens it completley shuts down
Jan 29, 2008 | Panasonic PT-50LC14 50" Rear Projection...
Projector Reset
Hi Here is the info for you :: Caring For The Air Filter The air filter should be cleaned about every 100 hours. If the indicators or a message prompts you to clean the air filter, clean the air filter as soon as possible. If the soiling will not come off the air filter, or it becomes damaged, then it needs to be replaced. Please replace the air filter as soon as possible. memoWhen you replace the lamp, please replace also the air filter. Turn off the projector, and unplug the power cord. Allow the lamp bulb to cool for at least 45 minutes. Apply a vacuum cleaner to the top of the filter cover and the air filter to clean. If the soiling will not come off the air filter, or it becomes damaged, it needs to be replaced. If the air filter needs to be replaced, contact your dealer to prepare a new air filter. Tell the dealer your air filter type. Turn on the projector power, and reset the filter timer. (1) While the projector running, press the MENU button to open the menu. (2) Choose the ?OPTION? on the menu using the / button, then press the button or ENTER button. (3) Choose the ?FILTER TIME? using the / button, then press and hold theRESET button for 3 seconds. (4) Choose the ?RESET? using the button. memo Incorrectly resetting of the filter timer (resetting without replacement, or neglect of resetting after replacement) will result in incorrect message functions. Here is the link to the users manual :: http://www.aboutprojectors.com/Hitachi-CP-X1250-projector.html Further Questions ?? Email Me hartmansp@inbox.com Have a great evening.
May 03, 2007 | Hitachi CP-X1250 Multimedia Projector
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
278 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
