Sansui DTV2700 27" TV Logo
Posted on Jan 01, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a black box on my screen, when it first came on it had a website adress in the black box. I have called my satellite people and they tell me to re frmat my tv screen.
The black box is about ten inches high and about 16-20 wide and it is on the lower half of my screen with picture around the black box
A
Anonymous
Turn off the closed caption it is set to T1 or T2
Robert Johnson
Level 2:
Sergeant:
  • Expert 395 Answers
  • Posted on Jan 01, 2008
Robert Johnson
Expert
Level 2:
Sergeant:
Answers
395
Questions
0
Helped
151966
Points
887
Shut off close caption, the caption is in text mode which puts up a black box.
12 inch black square in center of the viewing screen when I turn tv on or switch stations
The black square is a text box for the deaf. You can turn it on and off with the closed captioning button on your remote or from the closed captioning section in your television's menu.
However if you are connecting a cable box or satellite tv receiver you would need to turn the text box off from its menu. There is often a hidden menu that needs to be accessed on the cable boxes and satellite tv receivers that can be reached by turning it off and then immediately pressing the menu button on the outside of it. For more details about a specific cable box or satellite tv receiver call your cable or satellite company.
tip
You cant reset the bios password Of the Satellite A215 just by removing cmos...
I guess I need to remove the CMOS battery to be able to reset the BIOS of the Toshiba Satellite P300 - 194.
My problem is that I cannot access the battery. Where is it located?
Is there any backward password I can use for that model?
Please help!
Thank you!
Working on mitsubishi model number wss55809 plays for hours then out of nowere will go to blue screen then picture comes back by itself
Hello. When the screen goes blue it means that you have lost your signal from the cable or the satellite. It could be the cable which connects the tv to the signal supply source, the cable box or the satellite box. I recommend that you replace that cable.
If it continues call your cable or satellite provider and tell them what is happening as it could lie in their equipment, and not yours. Joe
2helpful
My 9505 satellite phone will not call
Hello. I am a Satellite Phone Repair technician. This problem that you are having is a relatively common one with 9505's. The phone will not call out until a sensor is replaced that tells the phone that the antenna is up. This repair usually runs around $250, and the phone will be as good as new. Feel free to look at our website page that shows all types of repairs , as well as instructionss on how to send in your satellite phone for repair, through the download of an RMA form. Just press here to view our satellite phone repair page--BlueCosmo Satellite Phone Repair, or you may also view our website at www.BlueCosmo.com. We do Motorola 9505 repair, Iridium 9505A repair, Iridium 9555 repair, and also Motorola 9500 repair, as well as rent, and sell satellite equipment, and airtime. Call us or check us out. Talk with you soon.
Sincerely,
Jeremy C
Director, Repairs & Sales
Hello my picture seems to have shifted upwards ie the top of the image is now at the bottom of the screen then there is a black line then the next two thirds are above the black line. I think on an old tv...
The problem was not actually the tv the fault was on the satellite box. I unplugged the box from the mains to reset it and the picture was restored to normal.
Hello,I have two flat screen HD televisions with black spots.
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
4helpful
2answers
How do i run a channel scan? there is nothing in the manual
Found this in the most frequently asked questions at the Dynex customer support website on page 3. the website is:(http://www.dynexproducts.com/pc-680-23-dynex-32-720p-flat-panel-lcd-hdtv-matte-black.aspx) You can also call the customer support telephone number at 1-800-305-2204. between the hours of 7am-12am CST. Give them the model number of you television and tell them you are having problems completing the autoscan of the television. I hope this information helps you with your problem. 1.How do I set up my channels or run an autochannel search? 2.Are you using a cable/satellite box, cable connected directly to the TV, or an antenna? 3.If you are using a cable or satellite box you must use the remote that came with that box to change channels. 4.Make sure you have the correct input selected to view channels via the cable or satellite box. For example, if the cable or satellite box is connected via component cables please press input and select Component 1 or Component 2 to view your channels. If you are using cable connected directly to the TV: 1.Press MENU. The on-screen menu opens. 2.Press < or > to select Channel, then press v to access the Channel menu. 3.Press ^ or v to select Air/Cable, then press < or > to select Cable. 4.Press ^ or v to select Auto Scan. Press > or ENTER. 5.Press ^ or v to select Cable System, then press < or > to select your type of cable or satellite system. You can select STD, IRC, HRC, or AUTO. If you are not sure what type of system you have, select AUTO. 1.Press ^ or v to select Start to Scan, then press > or ENTER to start scanning. Your TV memorizes all cable channels you receive. If you are using an antenna: 1.Press MENU. The on-screen menu opens. 2.Press < or > to select Channel, then press v to access the Channel menu. 3.Press ^ or v to select Air/Cable, then press < or > to select Air. 4.Press ^ or v to select Auto Scan. Press > or ENTER. 5.Press ^ or v to select Start to Scan, then press > or ENTER to start scanning. Your TV memorizes all analog and digital channels you receive.
URGENT CALL:- ACTIVEX Prompt Box
Change your security option to Low or Medium low, apply and Ok.
good luck
4helpful
4answers
Black box in center of the screen?
could it possible be a problem with closed caption setting....is this a square or rectangular box how big?
Top Sansui Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
