it was dropped with lens fully extended. lens is retracted and not exactly straight when turned on...
(More)
it was dropped with lens fully extended. lens is retracted and not exactly straight when turned on it tries to boot up but then shuts back down. the lens does not move is there a reasonable cure or is the lens out of track if not is it too costly to bother with repair
Batteries need charging message very often, even, with new fully charged or new non rechargeable...
(More)
Batteries need charging message very often, even, with new fully charged or new non rechargeable batteries, the camera can be put in the review pictures mode with no problem but when putting in camera mode the camera will go off or show change batteries message, or if I zoom the camera will shut off, it seems if I put batteries that are new (tested shows full scale in green) the camera will either shut down or show change batteries message. This is hit or miss, sometimes it will work for awhile with batteries that are not fully charged. The manual says use alkaline batteries. Does this really make a difference? I think there is something wrong with this camera. The camera is several years old, purchased new. When first given as a present this camera has always been tough on batteries. That is the reason I went with rechargeable AA batteries but the problem has been getting progressively worse even when using new non rechargeable batteries,
Re. Canon PowerShot A520. Lens is stuck about 97% open. The camera will not power on. The problem...
(More)
Re. Canon PowerShot A520. Lens is stuck about 97% open. The camera will not power on. The problem happened suddenly with no warning. The camera is kapoot!
LCD display shows up so light that if there is any light where I take a picture I can't see it in...
(More)
LCD display shows up so light that if there is any light where I take a picture I can't see it in screen, and I have to look through the view finder. What to do?
The camera will not turn on even with fresh batteries. Is there any combination of buttons i can...
(More)
The camera will not turn on even with fresh batteries. Is there any combination of buttons i can press to reset it somehow?
