Question about GPS Devices
Etrex Vista HCX Trip Computer Problem
Hi, I have a problem with the Trip Computer on my Vista HCX GPS. I can't seem to get the moving time to start. The trip computer remains in the "Stopped" mode even although I am moving. All other features such as max speed and elevation work. I have the track log on so I thought this would be what it is measuring, but this doesn't appear to be the case.
Any help would be appreciated.
SOURCE: eTrex Vista shows incorrect date
Thanks for the great advice. My problem is fixed!! Yay!
Posted on May 07, 2008
  • 3 Answers
SOURCE: eTrex Vista HCx freezes
Garmin released a firmware update for this issue. I downloaded it but will try it tomarrow on a long trip. hopefully it will fix it.
Posted on Sep 15, 2008
  • 3 Answers
SOURCE: gps not tracking satellites
the antena isnt the greatest, you can get a better external one, or make sure the screen is always pointing up, and your not under tree cover or anything as it will block the signal
Posted on May 31, 2009
  • 144 Answers
SOURCE: etrex vista hcx will not power on. It does when
maybe the battery is bad try taking the battery out and puting it back in
Posted on Jun 04, 2009
  • 3051 Answers
SOURCE: My Tomtom 130 GPS seems to be frozen.
Hello there:
first off i would consult the troubleshooting section in your users manual if you dont have it contact the manufacture of the device for a manual.
otherwise try this remove the power cord and press and hold in the reset button for 2 min this may help reset the unit.
If not remove the power cord and leave the unit sit for several hours it has a re learning function built in also if you can go to to view a downloadable users
Posted on Aug 05, 2009
SOURCE: Garmin eTrex Vista HCx searches for satellites but
I Am not able to give power to the unit.GPS is working fine. Fuse in cable is OK. Car outlet is working.
Posted on Aug 09, 2009
0 characters
1 Points
Somehow my map got erased from my garmin etrex vista, how can I get a map back on it?
meu etrex vista hcx não reconhece nenhum cartão de memoria, ja tentei pelo menos uns 3
diferentes que funcionam em outros lugaresaguardo uma resposta obrigado
Nov 23, 2010 | Garmin eTrex Vista HCx Handheld GPS...
How do I install maps from the Garmin US Topo 100K to my Garmin Etrex Vista HCx? I've put in a microSD card, then what?
You need to install the map software on your PC. From there, using the map select tool, select the maps you want to add to your GS unit and then send them to the microSD card which will show up in the SEND window.
Mar 29, 2010 | Garmin eTrex Vista HCx Handheld GPS...
I can't put maps on my Garmin etrex legend HCx
Your MicroSD card may be full just from the basic maps. Try larger card for additional maps. The vendors supply the minimum to keep the cost low and then force the customer to upgrade the resources at their own expense.
Dec 22, 2009 | Garmin eTrex Vista HCx Handheld GPS...
Garmin eTrex Vista HCx searches for satellites but doesn't find any, since yesterday. Device has worked fine for a few years, has the latest firmware
I have the same problem. Satellite screen shows nothing except the rings. When I open the unit, one of the chip looks like broken; its label says K43 and V5.
Aug 09, 2009 | Garmin eTrex Vista HCx Handheld GPS...
Cannot install new Garmin eTrex Vista HCx to my PC
The driver file should be in a folder called USB_Drivers on the Trip & Waypoint Manager CD. The install process is confusing - it looks like it has to install twice as after the first time it looks for the file again - carry through with this the 2nd time and you should be fine. I have had to reinstall the driver several times over the last few years - also when using a different USB port. So now I keep the driver file handy on the hard drive to save getting the CD every time.
Nov 11, 2008 | Garmin eTrex Vista GPS Receiver
Etrex Vista HCx will not calculate routes.
Please post the co-ordinate of the starting waypoint and I'll check it with mine.
Aug 12, 2008 | Garmin eTrex GPS Receiver
ETrex Vista HCx freezes
I have heard that there is an update 3.0 for the Vista.
Jul 12, 2008 | Garmin GPS Devices
GPS Devices Logo
66 people viewed this question
Top GPS Devices Experts
Are you a GPS Device Expert? Answer questions, earn points and help others
