Question about Brother MFC-8440 All-In-One Laser Printer
Dark mark at the edge of the page from top to bottom when printing
I bought a new toner, still shows a dark mark at the edge of the page from top to bottom when printing, What would be the problem?
  • guito777 Jan 10, 2008
    Thank you for your help. It seems I need a new drum.
  • Anonymous Feb 04, 2009
    This printed has made about 1500 copies max since bought in the fall... what is the best way to clean?
  • Brother Master
  • 1,113 Answers
Sometimes dirty carona, clean with blue tab on drum, if not then usally it is the drum worn out(expected life 20 000 prints) or less often it is the fuser roller stuffed
Posted on Jan 06, 2008
  • Soulvisitor
    Soulvisitor Jan 10, 2008
    These are a great printer, remember to reset the drum counter when replacing it.
    Cheers
Toner on paper edges
The cleaning blade inside of the drum unit is worn out. Replace the Drum Unit
May 19, 2010 | Brother IntelliFAX 4100 Laser Fax
Black line down the right hand side of prints
it may have had a dirt inside that may have been causing the lines. try cleaning with a soft dry cloth then try to print. reseat first the toner before you clean or wipe with a soft cloth
Sep 23, 2009 | Office Equipment & Supplies
HP Laserjet 5P shading edges of page
This is probably due to a defective cartridge, Charge Roller or Transfer roller.
Check the cartridge for a band of toner still on the drum.
Check the Charge roller for oil or smudges, this roller should be a lighter color and should be relatively free of toner or marks.
Same as the Transfer Roll, which will be dark, though excess toner should be evident.
A relatively smooth straight line is generally the cartridge.
A rather wavey or broken line is most likely the rollers.
You can however attempt to print a large amount of pages (25-50) in an attempt to clean the parts, however if either part is defective they will need to be replaced and no manner of printing will clean them.
Apr 14, 2009 | HP LaserJet 5p Printer
Dark band the length of the right side of the printed page
Hello sir; I suggest you go to replace a new cartridge, see what's happen.
Apr 07, 2009 | HP LaserJet 1020 Printer
Samsung ml-2010 printer prints vertical lines on the page
it may due to scearch on roller. check the roller for any scearch mark.
Dec 23, 2008 | Samsung ML 2010 Laser Printer
Toner not refreshing
I replaced the toner, but it still says toner life ended open front cover and repalce with new one. How do I resolve this
Oct 24, 2008 | Brother MFC-7820N Laser Printer
Black Lines
Do the black lines only show up when useing the adf???? Or do they show up on both the adf and the copyboard glass??? If it is only when using the adf...... The fix is easy.... you have to clean the smaller piece of glass that is to the left of the copyboard glass with windex or rubbing alchola. If it is with both you may need a new drum and blade or a new ufr... Good Luck
May 20, 2008 | Sharp AR-BC260 Color Copier
Print margins too large on Xerox DocuColor 12 - How do I reset?
Not sure this is what your needing but ,,
The Edge Erase default setting is No Erase, which enables the copies to print within 2 mm of each page edge. This is normally sufficient to remove shadows from the edges. If the dark edge is closer than 2 mm, you must set Edge Erase at Variable Erase.
The Variable Erase option enables the copier / printer to vary the amount of erasure from 0 to 50 mm in 1 mm increments. The same amount of erasure is applied to both top and bottom edges or right and left edges of the document.
  1. Select [Edge Erase] on the Added Features tab. The Edge Erase screen is displayed.
  2. Select [Variable Erase]. The Variable Erase screen is displayed.
  3. Under Top & Bottom Edges, use the [Up] arrow to increase the amount of erasure at the top and bottom edges. Use the [Down] arrow to decrease the amount of erasure at the top and bottom edges.
  4. Under Left & Right Edges, use the [Up] arrow to increase the amount of erasure at the left and right edges. Use the [Down] arrow to decrease the amount of erasure at the left and right edges.
  5. Under Original Orientation select the page orientation that most closely resembles the orientation of the document on the Document Glass.
  6. Select [Save]. The Edge Erase screen is displayed.
  7. Select [Save]. The Added Features tab is displayed and shows the new Edge Erase values.
Feb 05, 2008 | Xerox DocuColor 12 Printer
Brother MFC-8440 All-In-One Laser Printer Logo
219 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
