Question about Pioneer CDX-FM1289 12-Disc CD Changer
How do I fix the on/off switch to my cd cganger.(display unit on dash)
How do I fix the on/off control switch for my cd changer
"The unit is dead. There is no response when I press the on/off power switch of the display unit...neither does it respond to the remote unit..power is going to the changer... The fuseis good.
  • Anonymous Jul 15, 2008
    Same problem with two of these units, power is going to the units and ground checks good but both are dead.
  • 44 Answers
Make sure the ground connection has not been corroded or disconnected.
Posted on Feb 05, 2008
2002 jaguar XJR cd button on radio went dead? CD
it was a common prob with those cd changers in the boot/trunk disconnect it and let the head unit connect to it if still no good and the wiring/connectors are good the cd unit is faulty
Nov 07, 2017 | Jaguar X-Type Cars & Trucks
My obd and radio are not working what could be wrong I drive a bmw 1998
Is the display not working or just dark? The four bulbs across the top of it are easily replaceable if it is just dark.
The radios in these cars have several common problems after a decade of use. In a 1998, I would expect the display to go dark due to cracked connections on the surface mount resistors. The fix for that is here: http://www.frontiernet.net/~papi/e36_Radio_Display.html
The volume control frequently fails on these cars after a decade of use. It is optical so tuner cleaner just makes it worse.
I had one in one of my two '97s just simply go dead on me the other day. I cannot find the problem so it is getting replaced. JVC head units have adjustable display and button colors so you can match the rest of the lights in the dash. Get an antenna plug adapter and a conversion adaptor so that the new head unit will plug in to the existing plug in the dash. You will loose the ability to control a CD changer in the trunk, and your antenna amplifier will no longer amplify FM.
Apr 02, 2011 | BMW X7 Series Cars & Trucks
I get E-01 error of my cd changer
The fault is actually inside the CD changer, when one disc is selected the changer moves the gearing inside to slot from one CD to the other.
While this operation is happening the selection arm jams !!
Then giving an error at the radio display..
To fix the problem, disconnect the CD changer from the trunk of the car,
take off the top plastic slide cover,
with a small screwdriver slowly move the gearing so that the CD disc holder will move back to the load - unload position.
Pop out the CD holder.
Replace unit, reconnect the optic and power lead, switch on radio and the unit will work again,
grease the moving parts with light lubricant
Good Luck
Feb 24, 2011 | Mercedes-Benz C-Class Cars & Trucks
WE HAVE A CD PLAYER IN THE CAR ALREADY WITH A REMOVABLE FRONT BUT ONLY PLAYS ONE CD CAN WE FIT A MULTI CD CHANGER TO THE EXISTING CD PLAYER OR DO WE HAVE TO GET A COMPLETE NEW CD SET UP
several companies have multi disc CD players that are in dash..
and others have the changer in a remote location ( trunk) and are controled by the head unit..
Which model head unit do you have? It could very well fit into the later catagory and support a remote located disk changer..
Sep 29, 2010 | Car Audio & Video
Magazine won't eject
HI, the load motor has failed in your changer and , you will have to replace this. its part of the loading dock assembly and it turns all the gears associated with the loading and playing procedures.
If you are hearing continuous clicks, this will be the reason for the failed motor.
May 21, 2009 | Jensen XCH6RF 6-Disc CD Changer
I need to uninstall my Sony 10 disk car CD changer
When removing display from dash make sure you remove ALL proprietary cabling, otherwise your unit is worthless...since the car is junk, do WHATEVER is necessary to remove the cabling....don't beat yourself up if you cant do it as Cd changers are pretty cheap nowadays.
Mar 10, 2009 | Sony CDX-444RF 10-Disc CD Changer
IDC A09 installed in Fiat Punto
After incorrectly entering the code 3 times, the unit locks for 60 minutes. To clear it, leave it connected to the head unit and the radio switched on for an hour. After that, switch the radio off, disconnect and reconnect the cd changer, and enter the correct code.
Jun 18, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
Cd changer will not work
I had the same problem with my 2002 307SW.
I read on another forum to switch ignition off, remove CD changer from dash and disconnect. It then told me to remove the lid from the case unscrewing the screws marke 1 to 5 then remove the Cd's. The only problem with this is you need a special size 'star' driver bit which i did not have at home and could not unscrew them. What i did was to use a terminal screwdriver in the 2 larger screws that fasten the front plastic cover on the unit. Once I had done that I could remove the CD's.
I then connected the changer back up and inserted it back into the dash. I then powered the radio back up anf loaded a CD and the problem had gone away so I loaded the 5 CD slots and everything works fine now.
Jan 09, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
07 Armada
You will need to ask the dealer to replace the display again I'm afraid. I had a friend that had a similar problem with their Nissan. They had problems with display and the CD 4 times. If you try and do it yourself, that will void the warranty. Good luck
Dec 20, 2007 | Audio Players & Recorders
Pioneer CDX-FM1289 12-Disc CD Changer Logo
150 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
